SOURCE: pump runs continuously with not water
replace the pressure guage.
prime the pump by pouring in water in the impeller basket area and replace lid-try running pump again
SOURCE: aprilaire 600 humidier: water continuously runs
sounds like you may have it wired to a continuous power source vs one that shuts off with the furnace. The most common wiring is red to C & white to W
SOURCE: on start-up unit filled with
your manufactor is available monday thru friday. Some even Saturday. use pc to look up online.
SOURCE: GE top load washer will not stop filling with
Sounds like the water inlet solenoid valve is stuck. if you have the model number I can look up the part number for you
