Transmitter Battery
The estimated average battery life span of the transmitter is 2500 hours of use. If you suspect that the transmitter battery
has run out, contact your authorized Polar Service Center for a replacement transmitter. Polar recycles used transmitters;;;
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
Install the driver you received with the bluetooth device to make it work, If you did not receive or lost the disc search the manufacturers site with the product serial/model no.
The EX-10 was never intended to be an accessory to the IDA-X300, but should work with FM modulation like any other radio, by making sure the FM frequency is set the same on both units. There are four preset channels in the EX-10 but you can change each one to any frequency.
As for the bluetooth mic connection, you must have that connected for the bluetooth to work. You are better off installing a KCE-400BTi handsfree kit to get better functionality, increased phone compatibility, increased audio quality and the ability to use all of the newer iPods (Gen 2 iTouch, Gen 4 Nano and iPhone 3G).
