Question about Orion Car Audio & Video
My Orion HCCA D5000 esp indicator light is constantly on, even when the amp is off, and it seems to put a drain on my battery how do I fix that?
Derrick Schultz
    Top Expert:
  • Orion Master
  • 11,405 Answers
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 yearsmust try this bitman and reliable-store. Both are good
Posted on Feb 06, 2019
5 Related Answers
Anonymous
  • 35 Answers
SOURCE: orion amps
This one?
http://ampguts.realmofexcursion.com/Orion_HCCA250G5/
Often times you can take an amp to a repair shop and they will open it up to see if a simple fix can be done. I have an American made Orion amp to and paid $40 when all the mini fuse holders broke. The repair shop just made one big fuse. It still works great. An amp with such high quality as Orion can usually be fixed.
Posted on Aug 19, 2008
Anonymous
  • 53 Answers
SOURCE: Problem w/ Orion HCCA - D5000 Amplifier
Try checking the wiring configuration from your sub to the amp, if the resistance is too low it can cause to go into protection mode or the amp is damaged and you will have to get it service
Posted on Jul 11, 2009
Anonymous
  • 506 Answers
SOURCE: i have a orion hcca-d1200 and it keeps shutting
Possibly a shorted output transistor. If it was the power supply you would be blowing fuses, which I assume you aren't.
Posted on Dec 22, 2009
Anonymous
SOURCE: i have a d5000 amp and its wired up to a 15.2 hcca
make sure you have the frequency cuts right. if ur giving the sub anything lower then 30hz (assuming ur using 15's) the amp will cut out to protect the woofers from overload
Posted on Feb 10, 2010
Anonymous
  • 222 Answers
SOURCE: i have a orion d5000 amp was working good tried to
check your fuses
Posted on Jun 11, 2010
I have a orion hcca-d1200 and it keeps shutting off and blinking protect light and the esp indicator light. what could be wrong with it?
Nov 23, 2009 | Orion HCCA-D1200 Car Audio Amplifier
I have a d5000 amp and its wired up to a 15.2 hcca orion sub when i turn it up high volume,it cuts out anyone know why
Nov 18, 2009 | Orion HCCA-D5000 Car Audio Amplifier
My orion d5000 cuts out at high voloume for a few seconds then comes back on ????? why
Hello m3_sam,
You did not say what you have the amp wired to and what impedance. Since the amp produces more power at a lower impedance, it does make a difference.
At 4 ohms, the HCCA-D5000 delivers 1000 watts RMS. The higher the volume, the more the amp needs to draw from the battery.
Assuming everything is installed according to specifications, especially the dual 4AWG power and ground connections, it's likely that your vehicle battery/alternator is simpy not able to keep up with the current demand of the amp at high volume. You should probably consider upgrading your vehicle alternator and/or battery. In addition, consider a "Big Three" upgrade. This involves replacing or supplementing the battery positive, vehicle negative, and alternator cables to ones of larger gauge that will allow more current flow. Installation of a capacitor could possible solve the problem, but with the current demands of your amp, I wouldn't count on it.
Hope this helps.
Apr 22, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
if its hot its drawing to much current sound as if you have something improperly hooked up..if i could see your wiring i could help u out better steve
Feb 27, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Amplifier does not work
remove the speaker wires and re-test. If the amplifier powers on, without fault, you know the sub(s) and/or wiring are the culprit. If the power and ground are ok, take the amplifier in for service. The indicators are there to let you know of a problem. If it is an internal one, a certified tech will be required.
Dec 17, 2008 | Orion HCCA-D5000 Car Audio Amplifier
Orion HCCA-D5000
call orion or check e bay that where i get my parts for my orion.
Aug 18, 2008 | Orion HCCA-D5000 Car Audio Amplifier
Car Audio & Video Logo
Top Orion Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Joe Taylor
Joe Taylor
FastHarley
FastHarley
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
