Question about Toys
Bucket movements are way slow on 1845c case skid loader
Posted by Regan Walker on
4 Related Answers
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: I have a 1845C case
Sorry, but there is no easy way to do that...
You will need to get it somewhere that you can jack that side up and take the wheels off to be able to get it fixed right...even then it can be a pain in the rear...
Check the chain.. you may need to take a full link out and put a half link in there to get the chain tighter...
heatman101
Posted on Mar 15, 2011
fpsuperduty
SOURCE: need manual for case 1845C skid steer
My 1994 1845c case skid steer, Drive assy won't go forwards or backwards on right side tires.Left tires will operate fine.looked into chain area fluid was up, chains okay but fluid looked milky compared to the left drive assy.Could it be the right drive pump that has gone to heaven? When I bought it 2 years ago I noticed the right side DRIVE TRAIN was not as fast as the left when going forwards too.Could you please give me an idea where to look first? Thanks Frank
Posted on Jul 10, 2011
claudeinmo
Claude Kayser
  • 9098 Answers
SOURCE: How do I adjust creating on 1845c case skid steer
Cat® Skid Steer Loader ' Drive Chain Adjustment ... - YouTube
? 1:39
https://www.youtube.com/watch?v=FUtx88JifxY
Sep 27, 2011 - Uploaded by Cat® Products
Cat® Skid Steer Loader ' Drive Chain Adjustment & Chain Oil. Cat® Products ... Crane picking a skid steer out of a building. Unsafe - Duration: ...
How to change a drive chain on a case 90 XT - YouTube
? 2:27
https://www.youtube.com/watch?v=WBWVSpgZkKQ
Dec 27, 2014 - Uploaded by rayray haque
I made this video because I recently had to fix the drive chain on my skid steer. But there were no easily ...
Case 1845C Chain adjustment question - Heavy Equipment Forums
www.heavyequipmentforums.com/showthread.php?...Case-1845C...adju...
Mar 6, 2012 - 15 posts - ?5 authors
I noticed it was making a popping noise in the front left wheel, so I. ... It appears that this skid steer is pretty much indestructible if taken care of ... Case 1845c Skid Steer Problem - Heavy Equipment Forums
Apr 21, 2013
Case 1845C Uneven speed while travelling
Nov 24, 2012
1845c what things go bad - Heavy Equipment Forums
Jun 9, 2009
1845C Fan belt change question - Heavy Equipment ...
Apr 9, 2009
More results from www.heavyequipmentforums.com
Posted on Dec 28, 2015
Bill Boyd
  • 53812 Answers
SOURCE: controls for skid steer 2002 case 1845c are locked
check seat belt , safety bar and other safety switches for correct operation
Posted on Oct 02, 2016
How to remove bucket tilt cylinder on an 853 Bobcat skid loader
put the bucket on the ground and the tilt in a neutral position so that there is no load on the cylinder pins
turn off the engine
remove the hoses and cylinder pins
lift out
use plugs to control dirt from getting into the hose ends
Jul 26, 2018 | Heavy Machinery
Controls for skid steer 2002 case 1845c are locked
Oct 01, 2016 | Washing Machines
? 1:39
? 2:27
Mar 6, 2012 - 15 posts - ‎5 authors
Apr 21, 2013
Nov 24, 2012
Jun 9, 2009
Apr 9, 2009
Dec 28, 2015 | Cars & Trucks
How do you bleed the hydraulics on a Bobcat 751 skid steer loader?
Hi Joseph:
Usually hydraulic components will "self clear" any air in the system just by trying to cycle through the functions a few times.
Have to ask the question............
Did you remove and replace the hoses one at a time, or did you take them all off at the same time?
The reason I ask is............ Could there be a remote possibility that any of the hose onnection locations were switched?
Sep 23, 2015 | Toys
I have no power to the dashboard in the bob cat after door was opened with the bucket up
Blown fuse. Short in wiring to cab door. Unplug door harness replace fuse a be careful not to damage door with loader arms until you get new door harness it will not know if door is open or closed
May 09, 2012 | Bruder Cat Skid Steer Loader
My 1845c skid loader is not pulling forward nor in reverse
have a case skid loader 1845c. when asked to go in reverse after applying pressure to go in reverse the left side does not respond, but after a couple of seconds will go in reverse. does any opne know what the problem could be? Thanks
Feb 12, 2012 | Cars & Trucks
1845C Case skid steer wll not start every time. Is there a safety switch on this, besides the bar you pull down?
What year is your case? It will be either the Ignition cylinder or wiring short if an older model.Could also be your starter solenoid.
Jun 06, 2011 | Milwaukee Tool Case Heat Gun
Can't release the bucket on my 06 case 420 series 3 skidsteer. It works electronicly somehow.
You're going to have to find the wire that goes to that actuator and put power to it, possibly a bad fuse is causing this. We don't have to remove the bucket very often and this electric cylinder can get bound up with corrosion and pop the fuse. I just removed the electric cylinder from my skid loader that locks my system so I can release it manually. But then I don't know that there is a manual lever on your unit, mines an '86 vintage Toyota skidsteer that I built from 3 I had and rebuilt the 2J diesel engine. It works beautifully. I just love it. My only Case is a '72 Backhoe I rebuilt.
Apr 22, 2011 | AMC Wrangler Cars & Trucks
Need manual for case 1845C skid steer
Feb 17, 2010 | Milwaukee Tool Case Heat Gun
Toys Logo
153 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
