SOURCE: Brother printer dcp-330c error 46
press "menu" "black start" and "up arrow 4 times". that gets you into maint. mode to be able to reset purge counter. next enter code "80" by pressing up/down arrows and pressing "ok". press "black start" several times until you see "purge count". now press "2783" and "ok" to reset purge count. then press "black start" about three more times or until you see flushing count. again, press "2783" and "ok" to reset. now hit "stop/clear" a couple of times and press "99" to exit or use arrows to get to "99" . at this point, you may have to press "ok" to get out of maint. mode, but i think once you press 99 it backs out automatically. next time this comes up however, you will need to have your ink absorber box and flushing box replaced.
hth,
razors
SOURCE: unable to print 46
This is mainly due to dirty machine. Try following my steps:-
1. Press the Menu & Mono start keys. Next press the up arrow key 4 times to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. Press the mono start key several times untill the purge count appears on the LCD.
4. Enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero.
5. Press the stop/exit key to return to the initial stage of the maintanance mode.
6. Enter 9 twice by using the up arrow & set key's to exit from maintenance mode
SOURCE: brother printer dcp 330c - unable to print 50
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: unable to clean 46 error
Error "unable to clean" on Brother MFC
Hi there
Solution:
· Machine off
· Press 80
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
