Question about Schiller Medical
Hi!I have problem with the SCHILLER AT-2 machine. The S Wave is not plotted on paper. How to fix it?
Hello! Maybe somebody can help me.... Unfortunately I have a problem with the SCHILLER AT-2 machine. The S Wave is not plotted on paper. The machine expels the paper but without S wave (ecg line). PLEASE, SOME ADVISE
papoonick
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 18 Answers
Try rebooting the machine [email protected];then flush the print head. If it still doesn't print you will have to replace the head. There are some online companies that can guarantee to flush it.
Posted on Apr 04, 2019
2 Related Answers
Anonymous
  • 16 Answers
SOURCE: the schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
Posted on Jul 22, 2009
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: The ECG machine expels the
hi,
Your machines thermal printing head have some problem. Thats why it doesn't print any thing on the paper. Not possible to repair thermal head. You have to replace it with a new one..
ok
Posted on Feb 17, 2011
Ekg machine keeps beeping out of paper --- it has paper !
Check is the paper is properly installed or not. Here i have added a video wich will help you to proper installation of paper in the try. keep in mind the you have to use Schiller orginal paper.
Ajin
May 29, 2012 | Schiller Welch Allyn Cardiovit At 2...
At-2 lite model not printing visibly patient data and interpretation also have blurred upper part of EKG print. All leads are printed well. Is this setup problem or malfunction?
hi,
check the paper you have inserted. if the paper quality is bad then the printing can become bad. Use schiller original paper.
if again printing is bad then the thermal printing head of you machine is faulty or the. you have to replace the same.
ok
Apr 10, 2011 | Schiller Cardiovit At 2 Light Ecg Machine
I Have a Schiller AT-102 ECG The problem is that the paper wanders out the paper sensor area and i get out of paper signal. The paper tray is 211 mm the paper size is 209 mm and no matter what i do the...
Hello!
I have the same model (Schiller AT-102) and unfortunately the same problem. I've tried almost everything with the hope of solving the problem: I changed the tightening springs which push the printer thermomatrix to the roller. Also replaced the optosensor. And so on... But nothing changed the situation. I would ask you to tell if you already have found the cause and the cure. Thank you in advance!
Jan 29, 2011 | Schiller Welch Allyn Cardiovit At 2...
What type of paper do I need to use?
hi,
you should use original paper supplied by Schiller for AT2.
ok
Jan 16, 2011 | Schiller Welch Allyn Cardiovit At 2...
How to refill paper
hi,
watch the following video for paper loading in schiller at 2 will be same for ur machine also.
ok
Jan 08, 2011 | Schiller Welch Allyn Cardiovit At 2...
Schiller cardiovit at-2 we can only get 3\4 of a ekg it stops
hi,
ur Schiller at 2 has problem with its battery. just replace the same. its a12v battery.
also clean the paper sensor Whit an ear bud (do not use any chemical use only ear bud). u can see the paper sensor on the side of printer head. a square black portion.
ok
Jan 03, 2011 | Schiller Welch Allyn Cardiovit At 2...
Trying to refill paper and when i do that it stills says refill paper
hi,
use only paper for schiller AT1 . also check the paper sensor. slide the paper cover then look at is printer head side , u can see a small black square portion in the side . clan it with an ear bud. do not use any solution. after cleaning put the paper back and test again. use paper with black spot on the side. machine counts the black spot.
ok
Dec 22, 2010 | Schiller Welch Allyn Cardiovit At 2...
The schiller At-2 we have in the office is acting up. Model number 021-02609. Office number is 480-889-0508. The paper feeds and doesn't stop were needed and the ECG being preformed on a patient are not...
HI,
check the paper u have inserted. it should be Schiller original paper with page marking. also clean the paper sensor. u can see the paper sensor near the side of printing head. a small square portion. clean it with an ear bud, don't use any solution for cleaning only ear bud.
ok
Oct 13, 2010 | Schiller Cardiovit At 2 Light Ecg Machine
Schiller AT-1
I have a problem with ECG Schiller AT-1. In auto mode, it prints nothing but in manual mode it works properly. Could you help me solve this problem
Oct 16, 2009 | Schiller Cardiovit At 1 Ecg Machine
The schiller at 2 plus ecg machine not printing ecg
Jul 15, 2009 | Schiller Welch Allyn Cardiovit At 2...
Medical Logo
170 people viewed this question
Top Schiller Medical Experts
ray gallant
papoonick
Level 1 Expert
Are you a Schiller Medical Expert? Answer questions, earn points and help others
