Question about The Office Equipment & Supplies
My bizhob c250 is asking me to replace the tuner and imaging unit, i did but its still giving that same erro
Posted by udeme andy christian on
Pensivania Pensive
    New Friend:
  • 66 Answers
Toner chip and Drum chip.
Posted on Feb 07, 2019
How to reset the life of the drum unit of bizhub c250
you dont you replace the image unit which houses the drum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 29, 2016 | Konica Minolta bizhub C250 All-In-One...
My konica minota c451 is showing erro code c2551 and the print out is not sharp?
Remove the cyan (Blue) image unit. shake it along its axis. Are using 3rd party toner and image units replace with OEM. Open close front door to reset. Replace the image unit
Sep 09, 2015 | Konica Office Equipment & Supplies
Please install the image unit correctly and close all doors
replace the cyan image unit with OEM unit
Nov 15, 2013 | Konica Minolta bizhub C250 All-In-One...
Error c2652 in konica minolta c250
C - 2651 Cyan imaging unit EEPROM acces error
C - 2652 Magenta imaging unit EEPROM acces error
C - 2653 Yellow imaging unit EEPROM acces error
C - 2654 Black imaging unit EEPROM acces error.
Clean the connection between the imaging unit and the machine if dirty.Reinstall imaging unit or change imaging unit.
Try reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON the copier.
Keep pressed the Utility key when the Trouble resest message is displayed.
Release the Utility key and touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
Apr 16, 2013 | Konica Minolta bizhub C250 All-In-One...
Trouble code C2558
Hi rosemarie860,
C2558 on a Konica Minolta C250 means the machine is detecting an unusually high toner level in the
Black Imaging Unit. I suggest you take the Black Imaging Unit out, give it a gentle shake and pop it back in.
This usually does the trick, although sometimes only for a short period Other than that, you you might be
looking at replacing Black Unit.
Regards
m-press.biz
Feb 21, 2011 | Konica Minolta bizhub C250 All-In-One...
Black line across the top of every print on bh c250
Hi first do a cmyk test chart of each color if it happens when you do black copies then check the black imaging unit as it is not being cleaned and will give you black lines replace black drum unit
if it is on color copies black copies then the other thing to look at is the transfer belt unit and you may need to change the transfer belt
do the CMYK and you should get each color fully covered on each page see if there is any lines on the sheets in the same area you are getting the lines if so replace that color drum
Feb 12, 2011 | Minolta C250 Color Copier
My konica Minolta Bizhub c250 is printing an image that is faded in sections and reprints very subtly in other sections where it should be white space. Can you help me fix this problem?
It could be either your image transfer belt that needs replacing, or your fuser unit. Check the transfer belt first, that's the most common cause for "ghost images"
Jul 28, 2010 | Konica Minolta bizhub C250 All-In-One...
Image ghosting only on magenta
If the ghost is only on the magenta, your imaging unit is to blam.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Oct 08, 2009 | Konica Minolta bizhub C250 All-In-One...
Biz Hub C250 - code error C2551
Ahhh, you must be the same Macdaniel I emailed for clarification a short while ago.
C2551 relates to the Cyan imaging unit, the machine thinks the toner level inside the Cyan imaging unit is low.
Opening and shutting the main front door is the reset procedure. However if this doesn't work you should try the following
Remove the Cyan imaging unit, give it a bit of a shake and then refit.
Experience tells me that the above only works on occasion and you will probably require a new imaging unit. They are available for around £250.
Please be aware that the fault could also be down to a circuit board being defective, but this is less common.
Regards
Taminol
May 22, 2009 | Konica Minolta bizhub C250 All-In-One...
22 people viewed this question
Top The Office Equipment & Supplies Experts
Keith Love
James Cagle
James Cagle
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
