Question about Polaroid Televison & Video
Polaroid TV PU 6516 UHD went totally dead as I turned it on yesterday. How I can fix it?
Posted by Andrew Kowala on
5 Related Answers
Anonymous
  • 57 Answers
SOURCE: tv went dead while watching
Sounds like the Power Supply on the TV went bad.
Posted on Sep 24, 2008
freetek
Steve Allison
  • 5569 Answers
SOURCE: Made a "poof' sound now it's dead!
If your sets also produced kind of an acrid chemical odor when they failed, it was likely an electrolytic capacitor that failed catastrophically.
If you haven't done it yet, pull the plug on your set, allow it to stand for at least hours (better overnight) remove the back panel and look for the main power supply. It will have one or more transformers on the (probably separate) board. Check the board carefully for cylindrical devices anywhere between 1/4" - 1.5" in diameter and 1/2" - 2" high that have distorted cases or have dumped nasty looking deposits on the board around them.
Because of the way these turkeys fail, they may have damaged other parts as well so if you choose to replace them, don't be surprised if they immediately fail again. Depending on the manufacturing date of the sets, they may have additional capacitors waiting to fail; between ~ 2003 & 2005, millions of this kind of part were manufactured by otherwise reputable Asian companies but using (unknown to them) defective, counterfeit Chinese electrolyte that guarantees the eventual failure of the parts.
This kind of problem does not lend itself to DIY repairs.
Posted on Nov 23, 2008
Anonymous
  • 84 Answers
SOURCE: wii is dead
1. push the reset button and if that doesn't work unplug all cords and memory cards (including sd) from wii and unplug av from the wii and the outlet in wall. Wait 2-3 min or unplug the wii overnight and The trick i use was to literally smack the power supply on the ground and plug it back in. It seemed to work for a few weeks, until you buy a new power cord Don't call Nintendo unless you've got some money. it'll be $82 bucks.
Posted on May 06, 2009
Philip Frye
  • 44 Answers
SOURCE: Polaroid tv 2700 dead
I have to tell you that I'm finding that this is about the life expectancy of the first generation LCD TV's. It could be fixed/repaired for between $100 to $200 at a good TV Service Shop.
You may just want to put that money into another TV!
Blessings,
A/V Media Tech Guy
Posted on Nov 24, 2009
shaun taylor
  • 1527 Answers
SOURCE: Bought and set up our Samsung uhd 6000 yesterday. The tv worked for one hour and went blank. Nothing works. Help.
hi phone the place you brought it from, see if they can help thanks
shaun
Posted on Mar 19, 2017
I have a TLAC-02255 22" Polaroid led tv. When the set turns on the screen went totally blue the as you would press buttons such as menu or guide. The boxes would pop up in a blur almost as if to fade
Return your TV ... There is a manufacturers problem with your TV ... Return it and ask for either a different one or for yours to be fixed ...
Jan 17, 2013 | Televison & Video
Polaroid tv with no picture
No parts available for a lot of the polaroid sets-----model? total dead or sound or what?
Nov 05, 2012 | Polaroid Televison & Video
Help new power supply will not power up.
if you had a surge, it could have damaged more than just the power supply. When you plug in the unit, does the power indicator light up??? your main board could also have damage. The main board sends a signal to wake up the power supply thus turning on the TV. If you have to replace the main board as well, it probably won' t be economical to repair the set.
May 19, 2012 | Polaroid FLM-3734B 37 in. LCD HDTV
Blessings,
A/V Media Tech Guy
Sep 22, 2009 | Polaroid FLM-2632 Television
Dead tv
Repaired dead Polaroid TDA-03211C
I fixed a dead Polaroid TDA-03211C for my friends. When it failed it had just been turned on and then it went totally dead. This unit is a little over a year old and out of warranty. When I inspected the power supply it was continuously trying to start up but could not. With a Fluke meter you could see some of the DC output voltages rapidly rising and falling, but never getting to normal levels. I pulled the power supply thinking some of the capacitors were bad. Once I had the power supply out I used the Ohmmeter to check for any open or shorted diodes and/or transistors. To my surprise I found a shorted diode! I figured it would be the capacitors (typical failure in switchers), however they looked OK (not leaking goo or puffed out) and the TV is not that old. The failed diode (sorry I forgot to get the circuit designation) is a HER-304 (near the middle of the board with the cathode lead soldered to a small silver colored heatsink). The HER-304 is a 300 Volt, 3.0 Amp High Efficiency Rectifier in a DO-27 package. The DO-27 package is cylinder shaped with axial leads, 0.375" (9.5mm) long and 0.197" (5mm) in diameter. This diode is for the 20 volt source and is connected to one of the secondaries of the transformer. On eBay I found a vendor selling five (5) HER-305 (400 Volt units, better than the original) for $1.25 plus $7.95 shipping. Also I checked most of the Capacitors with a Sencor Z-meter, all that were check were OK. If a Cap. had another in parallel with it I did not check the other. I removed (un-soldered) the heatsink from the board and then the diode from the heatsink. I put it all back together and Yes, under $10.00 in parts (actually a $0.25 part) and a little time and the TV works again! 24 July 2009.
WARNING!!! WARNING!!! WARNING!!! Switch mode power supplies such as this use and generate voltages at current levels that can be LETHAL!!! If you DO NOT know what you are doing, find someone that does or buy a new TV, it is not worth dying for!!!
Jun 26, 2009 | Polaroid FLM-3732 Television
My 32 inch polaroid tv just shut off
Apr 24, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Nov 28, 2008 | Polaroid FLM-3732 Television
Tv went dead will not turn on
take the back panel at the bottom of the tv off and inside there there is a fuse most likely the problem, mine just did the same thing yesterday
Aug 03, 2008 | RCA P61930BL 61" Rear Projection...
Polaroid ttm-2401
To me, sounds like a picture tube issue. horizontal / vertical controls don't fix it. then its dead.
Jun 22, 2008 | Polaroid TTM-2401 TV
Televison & Video Logo
53 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
