Question about Faberware Kitchen Appliances - Others
I have a faberware air fryer and all the numbers for time and temp are gone..is there a sticker to replace it?
Posted by Lorna Kinard on
2 Related Answers
richie46
  • 12962 Answers
SOURCE: Faberware dual fryer won't turn on after kids heated with no oil in it.
The heater element has burned out - there was no oil around to keep the temps down and ....................
Posted on Jul 25, 2015
Bill Boyd
  • 53816 Answers
SOURCE: Where to find a power supply cord for the 2.5L deep fryer. Lost it. Called Faberware and Rep could not help me unless I had the power cord number. Duh, really??? I don't have the cord.
get in an electrician to identify the plug and then he can make up a power cord for you
Posted on Aug 18, 2016
Need an instruction manual for a Faberware Air Fryer, model 555989665. Any ideas?
Try callling 312-526-3760 (Monday-Friday 9:00 am-4:30 pm CST
to see if a manual is available.
Sep 12, 2018 | Faberware Kitchen Appliances - Others
I need A Manuel for my air fryer. Model number HF-919B.
Go to this site and you will find manuals for the Faberware HF-919B air fryer. One of these is a PDF that you can download and save on your computer and/or print.
https://www.airfryers.net/farberware-air-fryer-hf-919b/
Dec 05, 2017 | Kitchen Appliances - Others
I need an instruction manual for a cooks essentials air fryer
How to Use Your Fryer:
  • Remove all packaging materials, sticker, and labels.
  • Clean the basket and pan with hot water, soap and a non-abrasive sponge. These parts are dishwasher safe.
  • Wipe the inside and outside of the appliance with a clean cloth.
  • Place the air fryer on a flat and even surface.
  • Put the basket in the pan.
  • Plug unit in to an approved wall socket.
  • Place the ingredients in the basket and then put the basket and pan back into the appliance. The fryer LED will light up.
  • Set your cooking time and temperature by either choosing one of the 8 presets or manually set it with the "+" or "-" buttons. See "Cooking Guide" to determine the right time and temperature.
  • Once you have set your cooking time and temperature, press the "Start" Button.
  • The heating icon and fan icon will be blinking and this means that the fryer is starting and is circulating the hot air in the fryer. NOTE: During hot air frying, you will notice that the heating up icon will blink and stays from time to time. When the heating icon is on, it means that the temperature inside the fryer has reached the set temperature. When the heating icon is blinking, it means that the temperature inside the fryer dropped and is below the set temperature and is currently heating up to the reach the set temperature.
  • Some ingredients may need to be shaken halfway through the cooking cycle (see "Cooking Guide"), To do this, pull the pan out of the air fryer by the handle, the air fryer will automatically shut down. Then shake the contents in the basket, then slide the pan back into the air fryer and it will resume the cooking cycle. CAUTION: Do not press the button on the handle during shaking; this will detach the basket from the pan.
  • When the cooking time has been reacher, the air blower will stop in 20 seconds.
  • Pull the pan out of the fryer and place it on a pot holder. The cooking pan is VERY HOT do not put on surface that can burn. NOTE: Oil from the ingredients will gather in the bottom of the pan, so be careful when pulling the pan out of the fryer.
  • To remove the ingredients, press the button on the handle of the pan to detach the basket. DO NOT TURN THE PAN OVER. PLACE ON A POT HOLDER.
  • Upon placing the cooking basket back into the air fryer, the air fryer will automatically go to the previous cooking cycle and will repeat the previous cooking cycle, press the cancel button to stop and reset the air fryer if desired.
Mar 25, 2016 | Kitchen Appliances - Others
Why doesnt my deep fryer heat up ?
First it is good to check the fuse by unscrewing the plug.
If the fuse wire is not broken, it means that the deep fryer could be broken.
Nov 21, 2015 | Farberware Home Electric Faberware Deep...
Jul 25, 2015 | Kitchen Appliances - Others
My fryer won't turn on, what should I do?
Most small appliances have a printed circuit board that gets fried. (sorry for the pun) You have power to the unit so that's not the problem. I think it's time for a new fryer.
Nov 15, 2014 | Farberware Home Electric Faberware Deep...
Kitchen Appliances - Others Logo
54 people viewed this question
Top Faberware Kitchen Appliances - Others Experts
Dennis
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Faberware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
