Question about Apple MacBook Air
Hello ..i dont have sound on my macbook air its like deleted ,i tride to reset but didnt work.can you help me out ..tahnks
Posted by elite06 on
Anonymous
  • 1,305 Answers
Go to your system preference panel in the dock... click on the sound control icon. Look down at the bottom of the dialog box... there is a "MUTE" check box....make sure it's unchecked....
Also press the 'fn' key at the bottom left of your keyboard while pressing the f5 key... to raise volume...
let me know if that solves the silence!
K
Posted on Aug 06, 2009
Why my Kindle is not working on my Apple macbook air?
Close the Kindle app and restart it. If that does not help, try restarting your MacBook.
If that does not work, try deleting the Kindle and reloading it on your system.
Everything you got from Amazon will still be in your Amazon account.
Oct 07, 2015 | Apple MacBook Air
How i reset apple macbook air 4 digit pin code
Follow these Simple steps to reset your Apple MacBook Air - http://www.ehow.com/how_6934095_reset-macbook-air.html
and share any Mac problem with Apple Customer Service for help.
Apr 19, 2013 | Apple MacBook Pro Notebook
Forward slash not working on my macbook air
Did you change the system font to one you downloaded from the Internet? Some of those are missing characters. If not,
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Dec 04, 2012 | Apple MacBook Air
My apple macbook air shows a question mark when i turn it on
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
May 22, 2012 | Apple MacBook Air
I need 2 reset my macbook air i want to take all passwords off..
You will need to delete passwords within Keychain Access app. go to:your hard drive > Applications > Utilities > Keychain Access
In the Category section highlight the "All Items" Click on the first item and highlight it. go to the Edit menu at the top and "Select All"
hit the delete button on the keyboard.
it will ask if you are sure that you want to delete the items. click delete.
and you are done.
Dec 21, 2010 | Apple MacBook Air
HeLLo tHere AS you CN See My wHite MACBooK FirSt GeNorAtioNS KeyBoAreD HAS GoNe wroNG BeCAuSe SoMe LetterS Are tyPeD iN CAPS AND SMe ArNt AS weLL SoMetimes it GoeS iNto CAPS wHeN i DiDNt PreSS tHe CAPS...
sounds like the keyboard is failing check for debris under the keys use a can of compressed air, q-tips, and rubbing alcohol. If this doesn't fix the issue you will need to replace the top case (aka keyboard)
Dec 06, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Hi i'm selling my lap top (MACBOOK) and would like to erase everything in the computer before it goes out. HOW DO I DO THAT? THANK YOU
hello, they guy that posted above me suggested to reinstall Mac OS X. that obviously only works if you have the original disc. but if you dont, what you could do is to make a new Administrator account and delete the other one. that would get rid of all your user files. if it doesnt then you could delete the rest manually.
:) cjpipod (:
Dec 21, 2009 | Apple MacBook Pro Laptop Computer with...
I plugged my speakers in to the sound card and it
Hello!
You must try 2 options.
Try uninstall sound card drivers, reset comp., and again install sound driver.
In second case you must try new system, with full format hard drive, because you can have trouble with virus, and that is only safe way.
You can also try another sound card, but I think that is you sound card OK.
Nov 02, 2009 | HP (400745-001) Sound Card
My macbook stopped working
Hello, I give advise & support on using a computer. If you need basic computer skills and advise, I will help you. You can get support from me, via Msn live chat, if you purchase a $4 one hour online session. If you want to find out more, please send an email to [email protected]
Apr 02, 2009 | Apple MacBook Laptop Computer Mac...
Apple MacBook Air Logo
677 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
