Question about Hitachi Televison & Video
Hitachi 50 inch rear projection screen removal
Posted by rich prater on
  • Hi rich prater, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
5 Related Answers
Anonymous
  • 4402 Answers
SOURCE: Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Posted on Dec 05, 2007
Anonymous
  • 579 Answers
SOURCE: Hitachi Rear Projection LCD TV Lamp
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Posted on Dec 31, 2007
Anonymous
  • 4402 Answers
SOURCE: Hitachi 50" Rear Projection
TV: Viewing Screen RPTV - damage and maintenance
Posted on Feb 12, 2008
Anonymous
  • 4402 Answers
SOURCE: cleaning tv screen of hitachi rear projection tv
http://serviceman.site88.net/index.htm
Posted on Jul 07, 2008
Anonymous
SOURCE: Mitsubishi 50 inch projection tv
you probably have a problem with the convergence board.
Posted on Apr 05, 2009
What replaces the Hitachi 50UX26B/27K from bout 20 to 25 years ago.
Currently these rear projection sets are no longer made by any major company and your only recourse would be to search for a used one--see them on Craigslist a lot and not very expensive.
Let me know if you have questions as I am here to help.
Where Can I Buy A Replacement Screen For Hitachi 51f59a Rear Proj
Hi, I have a brand new in the box screen for a 50 inch rear projection tv. I was going to put it on ebay but if this is what you need and what I have--well we can go from there. Email me with any questions you may have. Thanks, [email protected]
Hitachi 50 inch how to remove screen cover'
Pull off Front speaker cover you will then see bolts holding face plate remove all screws then slide screen upward and Off.
HAPPY NEW YEAR!
Hitachi ultra vision, removing the front screen
Remove front bottom cover then remove all screws holding screen on Now slide screen up and out.
Wasp inside Hitachi 50" rear proj. tv
Pull bottom cover off front you will see screws holding screen on remove all of them then slide screen upwards and OFF.
50 inch hitachi green screen all the screen has a strong tint of green tried picture adjustment dont even get it close
I have the the same problem with my 60 inch Rear HD projection Hitachi. The bad part is we just bought a bulb 2 months prior to the green showing up.
Replacement protection scrren
Status Part Number Description Substitute List Price Dealer Price Obsolete KR01227 SCREEN/SHIELD $374.31 $299.45
try this
Hitachi 50 inch Rear Projection Color problem
Which sounds like a loose connection in the video or chroma section. you can carefully tap around affected area with a rubber screwdriver handle(not metal part) and see if it does come and go and look in that area for loose connections that needs soldering back. Hope this helps
Televison & Video Logo
Top Hitachi Televison & Video Experts
Ekse
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
