Kitchen Appliances - Others Logo
e
eric Posted on Feb 04, 2019
Have toastmaster and it will not saute - Toastmaster Kitchen Appliances - Others
Ian blob
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 10, 2023
Ian blob
Contributor
Level 1:
Answers
Questions
0
Helped
536
Points
Yup, same here. Mine won't work in saute or yogurt mode. Starts just fine in soup mode though
Billy Terrell
Level 1:
  • Posted on Dec 30, 2021
Billy Terrell
Contributor
Level 1:
Answers
Questions
0
Helped
536
Points
I'm having the same issue with the same model. Looking for answers
1helpful
I have a Salton 6l electric pressure cooker. How do I brown meat
Press the Brown button with the lid off before pressurizing. The Power Cooker PRO has a brown button for saut?ing. On the Power Pressure Cooker XL press any preset buttons with the lid off to saut?. These units have a Slow Cook feature with low pressure.
http://www.salton.co.za/instruction-manuals/630_SEPC01_Salton_Electric_Pressure_Cooker_Instruction_Manual.pdf
How can you choose your own time and temperature. And what is the buttons for sauting, braising and simmering?
as you do not refer to the make and model and fixya site has nothing to do with cooking appliances there is no possible way you can expect an answer , other that to get the correct web page for that manufacturer and address the question to them
I have a recipe which requires braising ( browning and then adding liquid). is a saute pan best for this?
definitely! The walls of the saute pan prevent you from spilling while you stir.
Apr 10, 2013 • Home
Where can I find an article about the differences between a skillet and a saute pan?
http://www.seriouseats.com/2010/05/equipment-whats-the-difference-between-a-skillet-a-fry-pan-and-a-saute-pan.html
Apr 10, 2013 • Home
Does my saute pan need to have a flat bottom?
You want to have enough space to fit everything in your pan. You also want to be able to slide your veggies back and forth in the pan which is must easier to do when the bottom is flat. Flat is also good because then the heat goes to every part of the pan equally so one side won\'t burn while the other side is still raw.
Jan 16, 2013 • Home
What would make the atc fuse blow in a 1999 chevy blazer?
jai un blazer 2001 avec un probleme de fuse qui saute seule du atc elle saute sur la route lorsque le 4x4 es engager apres quelque minute de route jai changer lencoder le module atc tout verifier le filage a l'oiel et jai rien trouver quelquun peu maidee svp
2helpful
2answers
Repalcement plates for Model 270A Toastmaster Waffle Iron?
There is no way you can get replacement plates for you Toastmaster cheaper than you can buy a new one, the most expensive Toastmaster waffle maker I found was $30. the cheapest was $15 shipping will be at least half of that.
3helpful
2answers
Toastmaster Breadmaker - bought secondhand, no manual, model 1148X Serial E6173
Oct,8'08 I found a Toastmaster BREADBOX Breadmaker Model 1148x but no manual. I just downloaded the pdf file for the 65 page manual and recipes from http://kitchen.manualsonline.com/manuals/mfg/toastmaster/1148x.html for free. There is a free signup for the privacy and terms and conditions.
Also, a couple of sites refer to an 800 phone number (did bnot call it so do not know if it works) that is the same as the one for customer service on the back of the manual Part No. 33519P02, copyright 2000 Toastmaster Inc. a subsidiary of Salton, Inc.:
Toastmaster, Inc. National Service Center, 708 South Missouri St, Macon, MO 63552
In USA and Canada call: Consumer Service 1-800-947-3744, Consumer Parts 1-800-947-3745
Hours: 8:00 a.m. t 5:30 p.m. CST, www.toastmaster.com, [email protected].
Hope this helps!
Top Toastmaster Kitchen Appliances - Others Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
