Question about Radio Communications
Tina Turner is sick? - Radio Communications
Posted by Ada Bill Acain on
How do I wire a Turner Plus Three mic to a Sears SSB Roadtalker 40 base radio?
Hello, We need the model # of the radio to tell you any info but here is the link to the Turner wiring manual. Sears radios are on pg. 21.
http://www.cbtricks.com/mic_manuals/turner/turner_mic_wiring_book.pdf
Sep 06, 2015 | Radio Communications
What is a dog spost to eat if u do not put this nonsense in my food
confer with your veterinarian about an appropriate diet and food for your dog. The cheapest and the most expensive do not always work. Feed them what is best for them.
Mar 03, 2015 | Turner Day & Woolworth Genuine Hickory...
Magnum delta force radio wiring diagram for Mic turner 2pluse 2
Based on the Delta Force Schematic and the Turner +2 diagram 1=White 2=Red 3=Black 4=No connection (Unless you install 2 scan buttons in the Turner +2) 5= Shield Switch the internal switch in the bottom of the microphone for Electronic Switching (Not Relay). :-)
Aug 24, 2014 | Radio Communications
Fan wont shut off in my 2001 nissian altima
Hi Tina,could be your blower motor resistor,it's located next to the blower,2 screws hold it on,remove electrical connector first,take to Autozone and get a new one,if it doesn't fix,they will take back and refund your money Tina.here's a link to the resistor Tina. Duralast Heater Blower Motor Resistor JA1219 at AutoZone com Here's a link showing you the resistor Tina. Repair Guides Blower Motor Removal Installation AutoZone com
Apr 12, 2014 | 2001 Nissan Altima
Mike wire color coat.
1 is shield (and may also need blue for astatic mic or red for turner mic)
2 is audio (white on astatic and turner mics)
3 is Transmit (Red on astatic mic or blue on turner mic)
4 is receive (Black on both astatic and turner mics)
If your mic isn't an astatic or turner, email me with what mic that you have and I'll try to help. [email protected]
Mar 18, 2010 | Radio Communications
Status bar appears but page turner is missing.
With a multi-page project open on the program workspace, click File in the menu bar and choose Print Preview.
In the Print Preview window that appears, click the Zoom In button and click Close to return to the project. The Page Turner button will now display.
Aug 28, 2009 | Broderbund The Print Shop 22 Deluxe Full...
GE Spacesaver microwave model: JVM1653sf001
It could be the Magnetron. First, If the unit is out of warranty, you can try to remove the rear cover (make sure unit is unplugged) and see if there is a blown fuse in the section that powers the Magetron. If all the fuses are good, I would suspect a faulty Magnetron. The Magnetron is the microwave tube which makes the food cook. They are not too difficult to replace. MCM Electronics sells them and you can call them with your model and they can find a replacement for you will be able to see how much it will cost.
http://www.mcminone.com/search.asp?keyword=magnetrons
1-800-543-4330
Good Luck,
- Jim
Jan 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Radio Communications Logo
152 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
