Question about Samsonite Photography
SOURCE: I can't open my samsonite luggage...the combo is stuck but I can
Turn your suitcase upside down. At this position all your numbers look
upside down. Now with the help of a torch light you should see a small
gap above the rotating thing (the one with which you change your
number) Take the first rotating thing and rotate from 0 to 9, at some
particular number you can see a small hole inside the small gap which I
have mentioned before. Do the same for the next 2 rotating thing.
When you are done you can see the small hole(a tiny spring like material is seen in the hole) in all the three small gaps.
Now you can open the number lock.
Posted on Jul 11, 2009
SOURCE: my samsonite hardcase luggage's centre no.lock not able to close
problem sloved
Posted on Oct 21, 2009
SOURCE: TSA locked our TSA002 lock on our samsonite bag
No. That's part of the whole purpose of TSA passkeys; they're held securely and only at ports. If it were easy for anyone else to get hold of them the locks which are TSA approved would become pointless.
You only have three options if you do not want to return to the airport:-
1. Get a locksmith;
2. Cut the lock off/drill it out;
3. If your lock is usually key operated (not a combination) then there will be a number next to the lock barrel (not the TSA number, that just tells the TSA which of their passkeys to use). A Samsonite dealer can order the correct key for you using the number and some even keep them in stock.
Posted on Oct 23, 2009
SOURCE: forgot my 3 digit number lock on my samsonite bag
lost 3 digit no on samsonite TSA002 lock
Posted on Dec 10, 2009
SOURCE: I have a TSA002 lock which came with the luggage
http://www.youtube.com/watch?v=OfchUwkEckI&feature=related
This link actually shows a man picking a TSA002 lock with a pair of standard tweazers. You can give that a try??
Posted on Sep 06, 2010
May 27, 2017 | Miscellaneous
Aug 28, 2016 | Luggage & Travel
May 01, 2014 | Samsonite Large Dial Travel Sentry Combo...
Apr 23, 2014 | Samsonite Tripod
Dec 29, 2012 | Samsonite Large Dial Travel Sentry Combo...
Try asking your questions again in the proper category since the expertise in this area is tripods and cameras, not luggage. If you ended up in tripods after starting in luggage, contact the FixYa staff to correct the problem. The other categories experts will be much better at answering your specific problem than the photo guys.
Sep 23, 2010 | Samsonite Tripod
Sep 05, 2010 | Samsonite Tripod
Jun 09, 2010 | Locks & Locksmithing
Sep 17, 2008 | Samsonite Tripod
326 people viewed this question
