Question about Boating
I am trying to find the fuse box on a 2002 SeaArk 17' side console. Can you help?
Posted by Smitty Hanks on
1 Related Answer
John Doe
  • 256 Answers
SOURCE: 2002 Cadillac STS My brake light long bar does not
Yes here is your help you got a couple of short there ,T,ake it in to a auto electric shop , Before it goes up in smoke,
Posted on Dec 07, 2012
Where is the fuel pump fuse on a 2002 kia optima located
Most Kia cars have fuse boxes that are well labelled. One is located in the engine bay. The other is in the passenger compartment, under the dashboard, either driver's side or passenger side. Check the fuel pump relay if you have confirmed that your fuel pump is not receiving +12V at the connector end. Some models have the relay as part of the main relay. Some have individual relays. These relays are located nearest to the ECU behind center console, screwed to the posts at the sides of the console.
Jul 19, 2014 | 2002 Kia Optima
Is there a fuse for power windows?
According with the Ford Owners Manual (page 226 and next) I suggest to check the next locations:
- Battery Junction Box fuse # 6-60AMP will feed Central Junction Box ( under driver side)
- the inline circuit breaker #47-30AMP, through the Accessory Delay Relay, powered by fuse #17-15AMP to the Window Control Circuit.
Check the fuses, and for 12v at the points. Then check for 12v at the driver side door switch pannel.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 19, 2011 | 2002 Ford Explorer
Trying to find the fuse location for 02 rendevouz radio. There is no indication on fuse panel door under glove compartment left side panel.
The radio fuse is located in the console fuse block located to the left of the glove box nrar the floor, the Radio fuse is number 37.
Feb 25, 2011 | 2002 Buick Rendezvous
2002 saturn sc2 won't disengage out of drive
These cars have a safty measure that if a fuse in the fuse box that gets blown or removed it will lock out the tranny..check the fuse box located on the passenger side of the car next to console
Jun 03, 2010 | 2002 Saturn S-Series
What is the fuse location for the power windows and for the rocker switches for the 2002 Ford Explorer? Thanks
for early production models
bjb (battery junction box) fuse #6
cjb (central junction box) fuse #17
for late production models
bjb (battery junction box) fuse #47
bjb (battery junction box) fuse #2
Apr 04, 2010 | 2002 Ford Explorer
2002 explorer power window fuse where
In the battery Junction Box check fuse # 6-60AMP will feed Central Junction Box (under driver side), the inline circuit breaker #47-30AMP, through the Accessory Delay Relay, powered by fuse #17-15AMP to the Window Control Circuit. Check the fuses, and for 12v at the points. Then check for 12v at the driver side door switch pannel.
Also uou should check the plug into the main window button console in your drivers door. The little piece of plastic around the door handle pops out when pushed towards the front of the vehicle. This gives you access to the buttons and harnesses.
Good luck (remember rated this help).
Mar 09, 2010 | 2002 Ford Explorer
Which fuse is used for the ecu on a 2002 nissan sentra?
There are three fuses. If your vehicle is equipped with the QG18DE fuse 17 (10 amp fuse ) is located under the dash in the fuse box. And fuse 34 ( 15 amp fuse ) and fuse 36 ( 10 amp fuse ) are located under the hood.
If your vehicle is equipped with the QR25DE fuse 17 (40 amp fusible link ), 34 and 36 ( both are 15 amp fuses )are all located under the hood in the fuse box
Dec 05, 2009 | 2002 Nissan Sentra
1996 Jeep GC fuse box diagram
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206):
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Nov 02, 2008 | 1996 Jeep Grand Cherokee
Instrument cluster and tail lights out. Which fuse on a 2002 f-250??
The fuse box box cover panel is on the left of steering column.
Fuse #41- 10A* Instrument cluster
Fuse #17- 15A* Exterior lamps
See inside of fuse box cover for a full chart of fuses and relays.
Aug 05, 2008 | 2002 Ford F250 Super Duty SuperCab
Boating Logo
121 people viewed this question
Top Boating Experts
ray gallant
Moderator Canada
Moderator Canada
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
