Question about Cooking
Can anything be added to cabbage to cut down on the smell while cooking?
Damon Nesselrodt
    Sergeant:
  • 197 Answers
Besides running the fan and putting a lid on it there is not much you can do. I would suggest grilling it outside. Here is a link to an awesome recipe... https://bluefarmfoods.blogspot.com/2018/11/bacon-stuffed-grilled-cabbage.html
Posted on Feb 03, 2019
Why does my dryer smell like rotten cabbage?
I would suspect your "green" concoction got into the lint that "lives" inside the machine. Unbeknown to you, dryers have a lot of lint inside that is never cleaned, it just builds up.
In the last 20 dryers I have repaired, about 10 had a shoe-box or two full of lint inside.
Perhaps the mixture you added made mildew or mold accidentally in the lint nest.
Also, if you are in a complex and you'all have shared exhaust, perhaps it is someone elses problem.
You could take your dryer completely off the circuit and close off the "shared" vent system.
Then , see if that makes any difference.
I suppose you could also try to run your dryer inside your condo for 5 minutes to see if the smell is coming from your dryer when it is not hooked up to anyone elses.
If the smell is from yours, you will need to completely dismantle your machine to get every trace of lint and smell out.
God bless your efforts.
Sep 11, 2015 | Samsung Dryers
Can I can cooked sauerkraut and pork
It depends on how you wish to cook it and the type of sauerkraut being used. Types with sugars shouldn't be cooked. It is best used as a marinate instead of direct cooking as the wilted cabbage will smoke/burn faster than the pork will cook. If its to be stuffed into the chops, that is possible but it depends on the thickness of the chops and any exposed sauerkraut.
Aug 29, 2015 | Grilling
WHAT CAN I COOK FOR TOMMOW
colcannon an irish dish consisting of cabbage and potatoes with onions
Mar 03, 2015 | Cooking
How can I desalt a sauce without adding water and cooking down to thicken again?
Add other ingredients until the salt level is tolerable. Unfortunately the only way to de-salt is dilution. Good luck!
Mar 25, 2014 | Avi Glatt Passover Entr es Stuffed Beef...
I've lost my recipe book which had the best corned beef and cabbage soup recipe. Does anyone have this recipe?
is this the one?
Tangy Corned Beef and Cabbage Stew
You don't have to be Irish to enjoy this lovely dinner.
  • 3 pounds corned beef, rinsed and cut into 1-inch cubes
  • 3 tablespoon quick cooking tapioca
  • 3 medium carrots, cut into 1-inch pieces
  • 2 medium onions, quartered
  • 1 small head cabbage, cut into 8 wedges (do not remove the heart)
  • 1- 10 1/2 ounce can beef broth
  • 1 soup can water
  • 2 tablespoons wine vinegar
  • 1/2 teaspoon dry mustard
  • 1/2 teaspoon horseradish (optional)
  • 1/4 cup molasses
  • 3 whole cloves
  • 1 bay leaf
  1. Place corned beef in pot. Sprinkle tapioca evenly over meat.
  2. Spread carrots, onions, and cabbage evenly around and over meat. In a mixing bowl, combine beef broth, water vinegar, dry mustard, horseradish, molasses, cloves and bay leaf. Add to pot.
  3. Cover and simmer at Setting #4 for 6 to 8 hours or until vegetables are fork tender. Remove cloves and bay leaf. Keep warm for serving at Setting #2.
    Makes 6 to 8 servings.
    Here is the link to recipes:
    Thanks
    Please rate FIXYA
Apr 09, 2011 | West Bend Crock Pots & Slow Cookers
How do I slice cabbage for cole slaw. How to use the pusher attachment.
You have to cut the cabbage into small enough pieces to easily slide into the chute. once you place it in the chute use the pusher to push it down. J.
May 31, 2010 | Cuisinart DLC-5 Food Processor
Rival roaster pan cooking instructions for corn beef and cabbage potatoes how long what temp
The Rival site has good cooking instructions:
http://www.rivalproducts.com/help.aspx?helpNav=1
Mar 16, 2010 | Rival 18 Qt Roaster Oven with Buffet...
Rotten smell from my air conditioner unit
make sure your drain hose is draining, It drains all the condensation from the unit, then you will need to clean the coil(s)
Jul 30, 2009 | Sharp CV-P09FX Air Conditioner
Cooking Logo
336 people viewed this question
Top Cooking Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Cooking Expert? Answer questions, earn points and help others
