Question about Kohler Electrical Supplies
I have a 12kw res kohler propane generator. It is just over a year old and has only 360 hours on it. Is it still under warranty?
Posted by Lanny Cook on
Carl Rock
  • Kohler Master
  • 2,281 Answers
1 Related Answer
Anonymous
  • 3 Answers
SOURCE: I have a new Kohler 12kw res generator on propane - backfiring
Is the outside air temp cold. These generators will backfire if it is real cold and if the propane pressure is low. It is suppose to be 11 to 12 inches of water colume at the generator fuel input. drygwals
Posted on Feb 20, 2010
Where is the speed sensor located on a 20resa kohler genset
Kohler Generator issue 20 RES - YouTube
? 0:24
www.youtube.com/watch?v=CT9u64dZna0
Apr 28, 2012 - Uploaded by Jeremy vanEyk
Brand new Kohler Generator Test cycle issue. ... Oh, and Mike, good call on the carb--that happens on some 20RES models. ...Indicates Locked Rotor (Lr). ... I'm on my second 20 RES-L,home depot swapped out the 1st one. ... Kohler 20KW RESA Whole House Standby Electrical Generator - Duration: ...
May 19, 2015 | Kohler 20resa 20kw Home Emergency Backup...
Trying to find what oil filter can be used in 14KW Kohler
what is the filter part number on the Generator now? Give that to an Auto parts place and they will cross it to what they sell
May 05, 2015 | Kohler Electrical Supplies
Kohler 30KW standby keeps throwing Under Voltage code - HELP PLEASE
The UV code has nothing to dow ith oil, poor oil would cause under frequency (low engine speed) Under voltage is caused by excessive load, short in the rotor/stator excition system, and/or AVR automatic voltage regulator. Of course loose wiring to will also cause it.
Feb 08, 2013 | Kohler 30 KW LP/Propane Industrial...
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
My 18RESL Kohler Propane Generator ran for 8.5 hours and shut down for overspeed. later it started up again and shut down for under frequency. Now it won't even turn over. Where do I start. I checked...
You have to reset it because it locked out on on under frequency. Just pullout the fuse on the control panel and then reinstall it a couple of seconds later. Now it will reset the fault codes. Hope that helps.
Dec 02, 2010 | Kohler 12 kW Emergency Power System -...
Feb 18, 2010 | Kohler 12 kW Emergency Power System -...
I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
Electrical Supplies Logo
112 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
