Question about Boating
SOURCE: No power
I had the same problem and i fixed it by unscrewing and installing the lamp cover on the bottom.. give it a try!
Posted on Jun 05, 2008
SOURCE: viewsonic n3251w - no power
A lot of TVs are having their power boards go bad due to a poor brand of capacitor (CapXon usually).
If small problems are noticed with the tv, the solution is to replace
the capacitors. However, once the TV gets to the point where there is
no power at all any more (not even a stand-by light) then the power
supply has to be replaced.
Visit Viewsonic's website or call your local Viewsonic repair shop to get a price on this board. They are usually under $100.
Posted on Nov 26, 2008
SOURCE: How can I test FSP250-60 ATV power supply to see if it works or n
A great way to test a PSU is to use a PSU Tester. The device allows you to see if all the circuits are getting power and it only requires you to plug it in to power. This allows the ability to test it safe and reliably without accidentally damaging hardware. Below is a link to a tester.
PSU Tester
Posted on Feb 03, 2009
SOURCE: PC Power up Problem
hi im josh in cebu phils. friend i suggest to check the two cables from power supply the 16pins and the 4pins 12volts.be sure you mounted it firmly to avoid this connection and to provde you with enough power to make the mainboard work. good luck.
Posted on Feb 23, 2009
SOURCE: Dell Dimension 5100 will not power up. Was
Have you checked your monitor? Try your monitor on another PC and check it is OK. Once you change the MB battery you effectively "Kill" the PC, as all the settings in the BIOS are removed and must be reprogrammed. You must enter the BIOS, and select "Default" setup and then reboot, you must do this regardless of what else is done first.(A bit hard when you can't see anything" You say... "tried different power switch and ribbon cable connector" (sic) exactly what "Ribbon cable/Power switch"? Anyway as said check monitor, if it is OK, we will proceed from there, then, you must check your video card, test it in another machine, if possible, to see if thats OK, if it is OK, then it is now likely that you may have a Mother board problem. If you can, try another Video card to see if you get Video on screen. see we need to establish "Known Good" items, once we know whats what, we can then go on. Now if any of these things tested are faulty, Monitor, Video card, obviously replace them, however IF they are NOT faulty, as related it may be the Motherboard, Remove the RAM, and see if anything is on screen? If yes, replace RAM, If still NO, then take any cards out, and check, if then OK, replace cards one by one until you get to the one that stops it, there is your problem, replace it. All we are trying to do is get anything on the screen, if we do, then you must redo the BIOS, as related before. Now if you get it going it still may not boot through to windows desktop, if this is the case, after you boot press F8 and select safe mode, when you get asked if you want safe mode or system restore, choose system restore and choose a date before you had a problem that should get you back. You just have to logically work through, until you find the faulty "bit" and replace it.
Posted on Feb 22, 2010
Testimonial: "Thanks for the confirmation!"
Jul 28, 2013 | Lowrance Lms 520c 5" Screen Color External...
Nov 03, 2011 | Lowrance LMS-332C GPS Receiver
Dec 27, 2017 | Lowrance Lms 522c Sonar Gps Chartplotter...
Jan 24, 2011 | Humminbird 525 Fishfinder
Apr 08, 2010 | Lowrance LMS-332C GPS Receiver
Jul 10, 2009 | Lowrance Lms 520c 5" Screen Color External...
May 29, 2009 | Lowrance LMS-330C GPS Receiver
May 08, 2009 | Lowrance Lcx 112c 10.4" Gps Fish Finder...
Oct 07, 2008 | Boating
Apr 26, 2008 | Lowrance LMS-332C GPS Receiver
147 people viewed this question
