Kitchen Appliances - Others Logo
Question about Kitchen Appliances - Others
Have a PEQ2 proofer that's not producing the vapor to keep bread moist
Posted by Darrell Brown on
What causes excessive mouth watering?
A watery mouth is caused by an excess of saliva produced by the salivary glands. Normally, the salivary glands constantly produce small amounts of saliva throughout the day to keep the oral cavity moist, keep bacteria in check and assist with digestion; the body reacts by swallowing periodically.
Sometimes the salivary glands produce too much saliva, resulting in difficulty swallowing or speaking, drooling or trouble sleeping. While not typically serious or permanent, excessive production of saliva can cause embarrassment and anxiety. Those suffering from GERD are especially susceptible, as the digestive acids present in the mouth can cause the salivary glands to produce as much as two teaspoons of saliva every minute.
Watery mouth usually goes away on its own. In prolonged or especially severe cases, it may be a symptom of a more serious underlying condition such as a sinus infection or other illness.
3answers
How do you soften Hard Brown Sugar ?
Warm water with yeast will turn it into alcohol
Humidifier not getting enough water
I suggest you buying the FOG RING: http://www.neotizen.com/main/main.php
This is really helpful for HUMIDIFYING any area, it is very cheap and it produces a lot of cold vapor.
How does the bread proofer work
a bread proofer needs still air that is moist. You can create those environments in your oven if you put a tray of water low in the oven and keep the oven low enough so as not to start baking the dough
Need manual for Baxter PC151-M38 Proofer/Retarder
I'm looking for an owners manual for a Baxter PC151-M38 Proofer/Retarder. Can anyone help?
Dec 07, 2011 • Ovens
1helpful
Bread does not rise enough I have carefully measured ingredients use rapid bake setting fleichmans rapid rise yeast checked water temp still having problems I have tried 4 times regular and rapid rise and...
A few tips.
The yeast must be absolutely fresh, use sachets instead of packets.
Keep yeast well away from the fats and liquids.
The fast rise setting will produce less rise than the full program.
You must only use strong bread flour.
Open lid immediately beep sounds.
It fell in the water and stopped functioning.Please help Thx.
I guess there is problem with the moist inside the gadget. Please do not start it until all the last drop of moist inside this will vaporize. U just need to uncover it and put it in sunlight for 3 to 4 hours or u can use blower also. but plz don't try to start it until the moist remains.
Hope this will work for u...... :)
2answers
Nu-Vu oven will not reach bakeing tempature?
HELLO IM A OVEN TECH AND SEEMS THAT YOU MAY HAVE A FAULTY ELEMENT DEPENDING ON THE MODEL YOU MAY HAVE TWOO ELEMENTS ,ONE IS GONE ,
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
