Question about Stihl Saws
SOURCE: stihl ts 400 wont start
If there is good fuel in the tank and the plug gets wet with fuel, and there is a good spark stating the obvious it should go, if not there could be a mechanical issue, piston scored, rings worn etc,
Posted on Apr 17, 2012
You seem to have covered most things so its now down to some diagnostic tests, compression test, you should be looking for 120psi at least, any thing under 100 and the rings are shot. A pressure vacuum test, this will tell you if you have an air leak either on the crank seals or a gasket, to do this you need to blank off both inlet and exhaust and use a pressure tester through the impulse tube ( this tube will go into the crankcase )
Posted on Oct 02, 2018
Oct 02, 2018 | Stihl Garden
Feb 08, 2016 | Stihl TS420
Jan 30, 2018 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Aug 14, 2012 | Stihl Ts 400 Ts400 Carburetor Carb Rebuild...
May 24, 2012 | Stihl Concrete Cutoff Chop Saw Clutch...
Apr 16, 2012 | Saws
Jun 16, 2010 | Stihl Ts 410 420 Cut Off Saw...
Mar 24, 2010 | Oregon Scientific Complete Carburetor for...
Mar 15, 2009 | Hand Tools
May 08, 2018 | Stihl Saws
151 people viewed this question
