Question about Rowenta Irons
I have a rowenta DW8194 stem iron i bought for my son - it will not heat up and when it does the light flashes on and off - then it will not heat up anymore-
Posted by Ann Howell on
5 Related Answers
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: Heats up but no steam coming out.
take down the iron and clean it the holes at the bottom of the iron are clogged up.good luck.
Posted on Apr 18, 2007
Anonymous
  • 18 Answers
SOURCE: My Rowenta iron will not heat up. The yellow light
Inside the iron is a piece of thermal metal the is supposed to make contact with a small ceramic pin with a metal cap on it. I think this was intended to be a safety device but they fail and the iron will not heat up. The part does not seem to be available so easiest way to fix is to put a small bead of glue on the housing that forces this to make contact.
Posted on Mar 06, 2009
David Shaub
  • 2976 Answers
SOURCE: Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
Posted on Oct 06, 2009
tbreeze47
Tom Carson
  • 3083 Answers
SOURCE: Rowenta iron will heat up and then shut down. Have
Irons use a potentiometer and thermister to control the heat on the element. One of these components is bad and needs replacing. If the iron's still under warranty, get another one. The cost of service would probably be as much as a new iron, but you could call an appliance repair shop to check.
Posted on Mar 12, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: I have a rowenta advancer DZ9080 iron that the
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
How do I fix iron?
If there is no heat, then the heating element has opened and is in need of repair.
Aug 29, 2015 | Rowenta Advancer High Pressure Steam Iron...
IRon heats standing but the light goes out when I set it horizontal to iron a garment. I think the cord is needing replacement but need advice.
If the iron is not moved while it is plugged
in, an internal safety switch will turn it off.
- It will turn off in 8 minutes if left vertically or
in 30 seconds if left on its soleplate or tipped
over. A red flashing light indicates that the
auto-off has been activated.
The above information is from the Rowenta DX1700 Owner's Manual. I think most, if not all Rowenta irons have the "auto off" safety feature. If your iron is going off before the 30 seconds idle time, the sensor may be defective. If you are letting it sit on the sole plate longer than 30 seconds, you may just need to work faster. ;-)
Jun 11, 2011 | Rowenta Irons
Rowenta d1700 red flashes and iron shuts off
I am on my 3rd or 4th Rowenta. I recently bought the Rowenta Effective, Model DX 1700. Once again, I am having the same problem as before, it shuts off after about 30 seconds. From what I am reading, many people are having the same problem. I'm going to have to guess, this is a product defect. Do I contact the company for a refund????
Dec 03, 2009 | Rowenta Effective DX1700 Iron with Auto...
My rowenta effective will not heat up.
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Dec 15, 2008 | Rowenta DG5030 Iron
Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
Sep 18, 2008 | Rowenta Effective DX1700 Iron with Auto...
Rowenta Iron problems
inside the iron is a thermal switch that has failed to make contact. Dissassemble the iron and you will see a small white ceramic pin sticking up out of the heating chamber and on tip there is a small contact. Above it is another contact that makes the heating element work. Easiest way to fix is to put a small bead of glue on the housing to force the contacts together.
Sep 02, 2008 | Rowenta DZ1700 Iron
Brand new rowenta professional won't heat
The mostly problem in that case is the internal terminal from cord to iron is loose ,open it and fix the the terminal cord to iron,or go to the nearest shop to repair that.
Thanks & good day,
Edgz
Feb 12, 2008 | Rowenta DZ1700 Iron
Irons Logo
220 people viewed this question
Top Rowenta Irons Experts
Colin Stickland
Colin Stickland
Paul Bade
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
