SOURCE: Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
SOURCE: FRIDGE WITH FRENCH DOORS AND
Your model must also have an evaporator on the top section because if the fresh food section deli has water below the trays you either have a door seal leak allowing moisture in or the fresh food section evaporator drain is also blocked. I really think your defrost drain is blocked and now everytime your refrigerator goes into defrost the condensate remains inside your refrigerator. Click Here=> Leaking Refrigerators Just What may Be Happening and read that page and then click here=> Leaking Refrigerators Read over all of the different ways leaks happenn and if this solution is helpful please rate the solution because I need all the rate's I can get. If you have questions I will be here so please ask, Thanks, Sea Breeze
SOURCE: I HAVE A GE PROFILE
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
SOURCE: Fridge is collecting water under the crisper
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
SOURCE: LG fridge making loud noise
Bonjour,
jeepers are we talking about a wheeze, a clunk, a whirr, a buzz, a rattle, a hum, random modulated or cyclic, low or high frequency, persistent or intermittent? Or could you just be hearing fan noise.
If it sounds like tin pieces clinking against something metallic. The fan blades may be striking ice or frost or the shroud.
Could be a bad or worn fan motor bearing, or a defrost problem causing frost build up.
Just a FYI
Some LG models have been reported online as having many many operating issues.
Hope this helps
