Question about Furniture
I have Transtherm 1T wine cabinet which is 15 years old. It does not keep freon. Once filled freon leaks out within a day and temperature goes up. What would you advice?
Posted by Alex Friedland on
Mr.Mike
  • 580 Answers
Look for some type of sealant let it cure and then try again- it may not be worth it
Posted on Feb 01, 2019
Jason Hanks
    New Friend:
  • 17 Answers
Unfortunately, 15 years is about the life span on most refrigerator systems these days. It's the weld joints in the cooling system that break down over time and eventually all the refrigerant leaks out. If you find the leak and fix it, you will likely have another one in a short period of time.
Posted on May 02, 2019
2 Related Answers
Jacques Alexandre
  • 183 Answers
SOURCE: My Transtherm Castle wine cabinet has accumulated
Check the thermostat setting; it may be set too high. If lowering the setting does not solve the problem, replace the thermostat.
P.S. The thermostat is what controls the temperature.
Posted on Dec 23, 2010
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: I have a Transtherm ,
Does not use a standard control rather an "Electronic" control
Posted on Jun 03, 2011
Mine is 10 years old. How can I refurbish the refrigeration system?
Certainly. Providing the system holds pressure, it can go indefinitely. Newer motor technology, in the compressor area would use significantly less energy, consider switching that out.
Aug 03, 2013 | Transtherm Ermitage Wine Cooler
Ice on the back wall; temperature went from 58 degrees to 34 degrees; had to shut off regrigerator
hi,
Wine cabinets work off of cycle defrost, so in order to built frost your temperature sensors are not working properly. I would look for corrosion on or in connections to be the fault or problem. Sensors report information to control unit and thats there only job. Its the control unit that dictates function. Look for corrosion to be the problem, clean connection and seal with RTV when connection a corrected.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 10, 2011 | Transtherm Ermitage Wine Cooler
My Transtherm Castle wine cabinet has accumulated ice in the lower chilling compartment, I need to know what is involved in thawing/defrosting the cabinet.
Dec 23, 2010 | Transtherm Castel Wine Cooler
On two recent occasions, my unit has chilled the wines down to about 36 deg.F. It has otherwise run fine for about two years, maintaining about 57 deg. F, consistently. Any idea what would cause such...
wine coolers are usually installed in cabinets or in a bar type situation where the airflow to them becomes more critical. the cooler has two sets of coils that can collect dust and dirt. once the coils clog with dirt, the fans cannot do there jobs by passing air over the coils. This is how the heat transfer takes place. One coil absorbs the heat from the inside of the cooler and the other rejects the heat into your home or outside of the unit. They should be cleaned once a month just like your refrigerator. This will make it run more effeciently. If this is not the problem, check to see if there is a supply register from your central heating and air system close to it. you may be able to get a diverter to push the air away from the cooler
Dec 05, 2009 | Transtherm Ermitage Wine Cooler
COOLER TEMP CONTROL SEEMS NOT TO BE WORKING.  TEMP GOES DOWN TO 42 AND STAYS THERE.
thats because 42 degrees is the optimum temperature for wine to be at. unlike other beverages wine coolers only go to 42 degrees.
Jan 21, 2009 | Transtherm CR212104 Wine Cooler
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Furniture Logo
206 people viewed this question
Top Furniture Experts
Tom Chichester
Marvin
Marvin
Are you a Furniture Expert? Answer questions, earn points and help others
