SOURCE: artista 180 driner
hi you need to get the right software for artista 180.I have just sold
my 180 and i still have the software on my computer. You need
the software called CPS 4.1...EMAIL me at [email protected] i might be able to get a copy off my computer for you
Lawrence
SOURCE: bernina artista 180 keeps warning to check top thread
Refer to your manual for maintenance and clean the machine as indicated. A sensor may be blocked by lint.
If this continues, the machine will need to be serviced by an authorized Bernina repair tech.
SOURCE: USB to Serial port cable for Bernina Artista 180
Just happen to be sitting in front a Bernina 180 at this very moment - with the connecting cable attached to a Keyspan USA-19HS Adapter. It is a current adapter available from either Keyspan (www.keyspan.com) or any number of computer retailers - physical or online. Seems to run around $30.00 just about everywhere. Auction sites may have bargain. Worked like a charm on an older XP computer as I was able to test the older software I had due to it having the necessary parallel port the the older dongle. While I am fairly certain this combination would also work on my Windows 7 computer, I am unable to test it as I have not come across a parallel adapter that will work with the older software parallel dongle. I've had other programs/peripherals that utilize usb to serial adapter (on my Windows 7) that have worked fine, so I suspect this would also be the case.
Hope this helps. If you have specific questions, please don't hesitate to contact us.
Happy stitching,
Kim
www.sewingexpressions.com
SOURCE: Artista embroidery program version 3.0 and Windows 7
For other versions and probably yours...
You'll need the following service packs to use BERNINA Embroidery Software V5 aand under Windows® 7 / Windows Vista™ operating system:
You'll find them at www.bernina.com\downloads
Hope this helped.
Rick
SOURCE: When i switch on my Bernina Artista 180 it blows
Almost-certainly due to the main switching transistor having blown, however this is not necessarily an easy fix ... very often when this happens it takes a number of other components with it ... I had one last week where no less than 10 other components had got fried (and I do mean fried beyond recognition, due to somebody having put a bigger fuse in - doh! - dont ever do this ... it's dangerous!). Best thing to do if you dont really know what you're doing is to get a complete exchange 'L'-print.
