Question about Bose Audio Players & Recorders
My Bose lifestyle 28 will not load disc - Bose Audio Players & Recorders
Posted by Tony on
5 Related Answers
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: Bose Lifestyle 28 not playing DVD
my brother i am not familiar with that model but due to my electroincs experience all dvd players are make up of the the same principle.there is a flat strip that leads from the lens of your dvd player kindly remove it and replace it this strip is probably broken after doing this get a dvd lens cleaner and clean your dvd lens and your on if you cannot do it your self take it to a tech os that they can handle it.this job should cost about $75.00 US. enjoy Henry Thomas from Belize
Posted on Mar 14, 2007
Anonymous
SOURCE: Bose Lifestyle V20 Error 180
OK talked with Bose just a minute ago and they were able to correct the issue.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Hope this helps!
Posted on Jan 26, 2009
Anonymous
SOURCE: I have a Bose Lifestyle 28 and want to hook my ipod up to it.
if there is a rca input available you can go to a local electronics store such as radio shack and pick up a rca MALE to 1/8 MALE cable
Posted on Feb 03, 2009
Anonymous
SOURCE: Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
Posted on Feb 24, 2009
Anonymous
SOURCE: open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Posted on Apr 22, 2009
DVD drawer will not open - stuck dvd inside
My only suggestion is to press and hold the eject button for a period of time (15 - 30 seconds). This might unlock the drawer. If not, I would contact Bose Customer Service directly.
2helpful
PS3 to Bose Lifestyle 28
hey, this is how i have mine set up.
Bose to PS3 via Digital Audio Optical
PS3 to TV via HDMI
This way you can get Full 5.1 surround sound, and good picture quality, also, go to the bose menu and set the optical source to your PS3.
Our BOSE system has been working great for years and years. We recently moved, set up the system, and now the system has been very moody reading DVDs and CDs. It will take sometimes several minutes to...
I had the same problem with a Lifestyle 35 system. Use a DVD lens-cleaning disk, followed by the latest firmware disk from Bose. This should clear up the problem.
6helpful
2answers
Bose lifestyle 48 says format unsupported for audio cds
Everytime I want to play an audio cd, it says format unsupported. This is happening very often. And I have also cleaned the cds,but still there is no difference. What is the solution?
2helpful
1helpful
Connecting lifestyle 27/38 to psp3
Your Bose system doesn't lead sound trough hdmi.
You must connect the optical cable with your lifestyle.
Change the sound connectionsettings in the menu of your ps3.
You also need to assgn the optical connection in the setup menu of the lifesyle. e.g. optical=aux.
Bose Lifestyle 28 setup disc
You would have to call 1-800-www-bose they can ship this part for free since you are a bose customer.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
2answers
Effect of playing pirated DVDs in BOSE
Only if your users are gullible or your pirate seller makes their own discs out of explosive or gooey stuff.  Mostly it's gullibility that gets into BOSE, though.
Bose Lifestyle 28 II
call tech support to see if they can help, they might set up a repair for you
Top Bose Audio Players & Recorders Experts
Ekse
 Francisco Mauricio...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
