Question about Crate Music
Crate GX-130C FIND WIRING DIAGRAM - Crate Music
tednugentlives
    New Friend:
  • 28 Answers
Https://www.amprepairparts.com/schematics.htm
Use the GX-65, its the same preamp shopwn just with 2 power amp sections
Posted on May 02, 2019
2 Related Answers
Anonymous
  • 157 Answers
SOURCE: Crate GX-20M burned resistor + popped cap values?
go to
http://www.crateamps.com/support/index.php
you may find what you are looking for there.
Posted on Aug 20, 2009
Philip Mullen
  • 4 Answers
SOURCE: Three button crate footswitch wires
My mate's crate uses two stereo jack leads similar to 6.35mm guitar leads but stereo. You can buy them anywhere.
Posted on Jul 06, 2012
Need amp schematic for a Crate model vc6112
Web page with schematics and requests:
http://music-electronics-forum.com/t26486/
http://music-electronics-forum.com/attachments/15279d1315547654-crate-vc6112.pdf
http://music-electronics-forum.com/t16609/
http://music-electronics-forum.com/attachments/7268d1260872380-crate_vc6112_271pwa_5.pdf
http://music-electronics-forum.com/attachments/7269d1260872394-crate_vc6112_271sch_5.pdf
http://music-electronics-forum.com/sitemap/f-60.html
User guide at link below from 1998 has mailing address in St. Louis.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwit2JO06LbZAhVG2GMKHflPAxEQFgg4MAI&url=http%3A%2F%2Fpdfstream.manualsonline.com%2F6%2F6d0e7f56-c06e-40bc-9925-bb1c66338de7.pdf&usg=AOvVaw1Qy5Pze8vKekErxgjmMg0U
Crate VC 6112 Owner Manual
Feb 21, 2018 | Crate Music
Where is the fuse located on a Crate GX-15?
make sure it's unpluged! then take out the chassis, and look for it on the circuit board. I don't think that one has one.
Oct 09, 2016 | Crate Music
How to fix the input plug on a Crate GX-15 guitar amp.
If u can bend the 2 prongs back towards plug end it. Will work on prong rides on tip of it the second rides in between the to nylon rings on it if that doesn't work any radio shack carry it for about 1-2 dollars
Jan 02, 2015 | Crate Music
Gx 15
Amps have fuses inside. Check them if they are blown. After replacing, if it keeps blowing, then you have a short that needs to be fixed. Good luck!
Mar 27, 2014 | Crate Music
Three button crate footswitch wires need to be refastened. I need a wiring diagram.
Sep 16, 2011 | Crate Cfs3
CRATE GX- 212 HUMS WHEN TURNED ON AND CHIRPS WHEN SHUT OFF. NEED SCHEMATIC AND ADVICE TO ISOLATE THE BAD CAP IN WHICH CIRCUIT THAT IT IS OSCILLATING.
Witth an oscilloscope analyze the ripple voltage across C67, C70, C14, and C12. Pay close attention to the last two of these which are on +/- 15 volt lines.
The "chirp" when shutting down is LIKELY normal and would probably be from teh DSP effects unit as it goes down. The voltages go out of the operating range and the device essentially goes nuts for a second or so.
Sep 16, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Amps broken need to fix it
Their may be a schematic on the inside of the amp.I don't remember if Crate puts one or not. And I have had several Crate amps. never needed repair except for tube replacement. If there is not one in side , go here and find what you need . http://www.crateamps.com/support/warranty/ Good luck DFD please rate me TK U
Apr 18, 2009 | Crate Music
Looking for a circuit board manual or diagram for a crate mx120r guitar amp
You can try Loud Technologies @ 866-858-5832, [email protected]
They hooked me up with parts and schematic for my Crate G212XL.
Apr 18, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Music Logo
307 people viewed this question
Top Crate Music Experts
Ngoro
Are you a Crate Music Expert? Answer questions, earn points and help others
