Apex Digital GT2715DV 27 in. TV/DVD Combo Logo
Posted on Aug 05, 2009
Parental level says its been set but i never set a pass code, what could it be
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Aug 05, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
1690
Points
24
Hav your kids tempered with it or do u hav kids
Unlock code parent
for ps3 the default is 0000 if you go into settings and restore the ps3 to default it will reset it to that
if its PS2 go the link below:
http://www.wikihow.com/Reset-the-Password-on-Your-PS2
for the wii go here:
http://en-americas-support.nintendo.com/app/answers/detail/a_id/2982/~/forgot-parental-controls-pin
and for xbox do this:
If you've forgotten your pass code, you can reset it by answering the pass code question you set up parental controls. Here's how:
1. On your console, go to Settings, and then select Family.
2. Select a content control setting to change.
3. When you're prompted, enter any pass code (even though it's incorrect).
4. When you're notified that your pass code is incorrect, select Reset Pass Code.
5. When your pass code question appears, use your controller or chat pad to enter the answer, then select Done.
If you can't remember the answer to your pass code question, you'll have to contact Xbox Support for further help.
...............hope that helps
I bought a xbox 360 and it has a parental code blok on it and I do not have the code how can I reset the pass code also do not have Answers to the ? So please help
Parental Control Override Code:
Go to Settings
Highlight Parental Control
When the screen pops up that says Enter Pass Code press: X, Y, Left Trigger, X
You'll be taken to the parental controls screen where you can disable the password previously entered -
If this does not work, Contact Xbox support (800) 469-9269
I have a Toshiba SD-K730 DVD Player I am trying to set the Parental Lock limit what type of movies are viewed. Can you help?
Parental control setting
Some discs are specified not suitable for children. Such
discs can be limited not to play back with the unit.
1) Press C or D to select "Parental", then press B
or A until the level you require appears.
Level Off: The parental control setting does not
function.
Level 8: All DVD software can be played back.
Level 1: DVD software for adults cannot be
played back.
Select from the level 1 to level 8. The limitation will
be more severe as the level number is lower.
2) Press C or D to select "Password".
Press Number buttons (0-9) to input a 4-digit
password. Be sure to remember this number!
• If you input a wrong number, press CLEAR.
3) Press ENTER to store the password.
Note: Now the rating is locked and the setting cannot
be changed unless you enter the correct pass
word.
4) Press OPEN/CLOSE to activate Parental control
setting. (See "Temporary disabling of rating level by
DVD disc" on page 36.)
Notes:
• Depending on the discs, the unit cannot limit playback.
• Some discs may not be encoded with specific rating
level information though its disc jacket says "adult." For
those discs, the age restriction will not work.
To change the parental level
1) Press C or D to select "Password".
2) Press Number buttons (0-9) to enter the password
you have stored.
3) Press ENTER.
• The rating is now unlocked.
4) Press C or D to select "Parental", then press B
or A to change the parental level.
5) Press C or D to select "Password", then press
Number buttons (0-9) to enter the password.
Note: You can change the password if you want.
6) Press ENTER.
Now the parental level is changed and locked.
If you forget the password...
1. Press OPEN/CLOSE to open the disc tray.
2. Remove the disc.
3. Press OPEN/CLOSE again to close the disc tray.
"No Disc" appears on the screen.
4. While holding STOP down on the front panel,
press 7 on the remote control. "PASSWORD
CLEAR" appears on the screen.
5. Enter a new password again.
hope this helps
John
It won't play t or m rated games
That is because the parental settings are still on the Xbox360. To remove them, you must be 18 or older on your profile.
  1. Go to My Xbox and open System Settings.
  2. Select Family Settings, Console Controls.
  3. Select Game Ratings.
  4. Select the Entertainment Software Rating Board (ESRB) rating level you deem appropriate. When you select a rating, you'll see a definition of that rating.
  5. To set a pass code to limit who can change your Family Settings, selectSet Pass Code from the Console Controls screen and follow the on-screen instructions.
  6. After you've set your code, select Done from the Console Controls screen. When prompted, select Yes, save changes to put your new settings into effect.
2answers
2answers
Need master pass code to a ps2 to play movies
There is no master pass code, but there is a code to reset the parental settings. It's important to note that 7444 is NOT the password. You have to hit SELECT when asked for the password. That is where you enter 7444 to clear the code.
Here is the procedure to reset the parental lock code:
Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
When the screen asks for the code, press the SELECT button, then enter in the code "7444".
The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
How do you reset ps2 parental setting
press 'select' button--> 7444--> enter new pass code--> re-enter new pass code
hope this helps :D
1helpful
2answers
My PS2 wont allow me to watch movies about level 2. its getting to the point that i cant watch ice age. i tried 7444 but it didnt work. i bought it from Gamestop used and they said that they didnt know of...
1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
2. When the screen asks for the code, press and hold the SELECT button, then enter in the code "7444".
3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
Parental controls
Violence, sexuality, and all-around bad behavior abound in many Xbox games. That can be fun for adults but scary for children. Here's how to activate built-in parental control features. Turn on the Xbox console without a disc in the disc tray. From the dashboard display, choose Settings > Parental Controls. Select Pass Code and press buttons on the controller in any sequence. Remember what buttons you pressed and the order in which you pressed them. Select Games and choose the maximum rating level you want to allow. Xbox will also allow you to set maximum rating levels for DVD movies.
2answers
Does xbox have a parental controls?
Top Apex Digital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
