Question about JUMP START SYSTEM
I changed out the old battery in my B&D 500 jump start but it will not indicate on the lights that it is charged. It keeps showing the red recharge light.
Posted by Ron Angleman on
  • Abdul Manjothi
    Abdul Manjothi Apr 02, 2019
    check with fan belt if its tight enough
5 Related Answers
Anonymous
  • 2985 Answers
SOURCE: when i try to charge my battery the red light keeps flashing
Could be battery or charger. 1. Buy new battery. Still in trouble? 2. Get new charger Its good to have two batteries
Posted on Jun 11, 2007
alicantecoli
Colin Stickland
  • 22485 Answers
SOURCE: 2003 BMW 525i--could an improper jump start blow a fuse?
new altenator,sounds like you put the cables on the wrong way round
Posted on Jun 14, 2009
Fred Yearian
  • 5603 Answers
SOURCE: why my 28v doesn't fully charge
One or more cells of the battery have gone bad. The technique of measuring the state of charge of the battery is VERY limited.
I would recommend letting the battery cool after charging... THEN in a day, charge it again without using it. Do this for several days and see if the battery improves. If not, time for new battery.
DO NOT discharge these batteries beyond the point where the tool starts to slow down. You will reverse charge the weakest cell from the ones still deliveing power and the reverse charge will permanently damage the weakest cell.
Posted on Nov 26, 2009
A Miller
  • 8404 Answers
SOURCE: on a vector jump start system, does the green
2 - 3 red lights indicate not fully charged. Green light = fully charged.
Not fully charged does not mean it will not function. For best results, your device should be fully charged. If you have an emergency and are not fully charged, it will not hurt to try to help with a partial charged device IMHO
Thanks for posting at FixYa.com
Posted on Dec 13, 2009
Boneebone
  • 973 Answers
SOURCE: I have been charging my 2 million candle power
It should take 10-12 hours, any longer the battery is no good, you can test the battery using a Volt Meter, the battery should be reading 12 volts, any less and the battery will need to be replaced. You can order a new one from Black and Decker, they purchased Vector in 2006, here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Posted on Jun 17, 2010
Our cordless hedge trimmer will start but keeps stopping after about I minute it won't cut bushes have tried to recharge. How long does it take and should a light show to indicate it is recharging. Th
Most chargers will show a green light when charged
That could take an hour
You have to or I do,charge all my items every 3 months
Not uncommon to have a failed battery in less than a year
Ideally four years & fair amount of use,but some do fail
Oct 29, 2014 | Bosch ASB Cordless Hedge Trimmer/Grass...
How do you recharge jump start system
put a battery charger for a car on the + and - leads and this will recharge it if you do not have the correct power pack recharge transformer
Jan 09, 2012 | Stanley Black & Decker Stanley J5c09 500...
Siemens charger for hearing aids starts charging and then after some hours one light goes red
Its a warning sign for a faulty battery, the red light comes on if the battery is faulty or if you are trying to recharge a non rechargeable battery.
May 03, 2011 | RTO 1 Siemens Pure 500 Open Fit Hearing...
I have a duralast jump starter BP-DLG. i cannot get it charged. i have pluged it to a standard electrical outlet and now it is dead. i have used it in the past and it worked very well. i mis-laid my...
My Duralast Gold Jump Starter Model BP-DLG will not take a charge. When it is plugged into the charger it shows fully charged; when I unplug it it goes dead, will not start and the red light shows. I have used it about 4 times in less than two years.
Feb 20, 2011 | RoadPro Road Pro 12 Volt Dc Portable...
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
When I placed my Lithium Ion Battery in the charger it doesn't carge the batter and the red light that's supposed to stay lit while it's charging keeps on blinking on and off.
How old is the battery?
It's very possible that the blinking light is indicating a bad/old battery. These rechargeable batteries after so many cycles lose it's charging capability and the fault system built into the recharging base will indicate by giving you the red light on & off. Energizer rechargeable station is a good example when it detects old or bad batteries.
Nov 08, 2009 | Casio Exilim EX-Z57 Digital Camera
Flashing red light
It is an indication that the battery is beginning to fail. Portable system batteries have a useful life of approximately 300 to 500 recharge cycles on average. (Some last longer, some shorter)
If the battery is over a year old, then the warranty on the battery is expired. You'll need to purchase an new battery
Feb 26, 2009 | Dell Latitude D510 Notebook
My Dell Latitude D610 Battery Stopped Working
The battery light flashing RED/AMber is an indication of a failed battery.
Portable batteries have a life expectancy of 300 to 500 recharge/discharge cycles. (roughly 18 months under normal use) After that, the charge life starts to drop off and eventually it will not hold a charge. Because of this, the battery is considered a consumable item and is only warranted for one year from the manufacturer.
Since all the systems listed in the post are D610's (4 to 5 years old) it is not surprising that the batteries are failing.
Dropped Puck, if you replace the battery and a new battery doesn't charge/run the system, then the charging circuit on the MB is failed.
Feb 22, 2009 | Dell Latitude D610 Notebook
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
JUMP START SYSTEM Logo
191 people viewed this question
Top Vector Vehicle Parts & Accessories Experts
Sheldon Dedek
Lawrence Oravetz
Vernon Taylor
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
