Question about Xerox Office Equipment & Supplies
Xerox 4112 fuse blowing in F10 position on IOT PWb started with error code 010-315
I checked door latches, Changed both fuser rollers, changed fuser clutch, changed 3 heating elements, checked and reset punch unit. pulled fuser unit and fuse still blows when power up. pulled image drum and fuse still blows on start up. checked all gears in fuser moving freely. cant figure why fuse blows.
Posted by Colonial on
Derrick Schultz
    Top Expert:
  • 11,405 Answers
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
Posted on Feb 01, 2019
1 Related Answer
Tim Whalen
  • 3074 Answers
SOURCE: creda compact 3 37301 tumble dryer pull down door.
I would suspect thermal fuse, easiest way to test is to tape wires together and start dryer. Safety note if left like this it will start a fire. It is located on the back of the dryer and has two wires connected to it. Here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Usually, failure of a thermal switch is caused by extreme heat: meaning that the dryer is not venting properly, clean dryer of lint inside and outside as well as the vent tube. Good Luck Tim
Posted on Dec 17, 2010
Hello every one, i have iR Canon 2420 copier, first time i have a problem on the fuser and i changed it with the new one. After that the machine copy correctly but the text copied will be erased easil
Dear
The fuser unit consiting of two pars
1-fixing film assy. (Heter unit)
2-fixing unit-(Complete set.)
if you have replaced new fixing film assy. in old fixing unit-this may be the result due to the pressure roller and it allied parts.
if you have replaced complete unit then check you toner and paper properties.
Thanks.
Dec 02, 2014 | Canon Office Equipment & Supplies
What call service 3 in Panasonic kx-mb1900
CALL SERVICE 3" means that the temperature of the fuser does not rise up to or exceed a constant temperature.
The temperature is monitored with the thermistor inside the fuser and detected with the voltage input into IC 300-D19
Apr 26, 2014 | Panasonic KX-FL611 Plain Paper Laser Fax
Fuser unit failure
Yes you can fix the same fuser but you will need advanced skills, this problem can be because you need to replace the upper fuser roller usually is the part that first come damaged, in case this part is ok, check the lower pressure roller, if both are fine, check the heating element, it will be one of this 3 parts.
Aug 16, 2013 | Brother HL 5250DN Laser Printer
When I print with my brother hl-2070n...the print out is very very faint. i have changed the toner and drum...any suggestions?
if you printing is just faint, need to replace toner, but if your printing is faint and blurry, need to add grease to the fuser film roller, need advanced skills for that, disassemble the fuser unit take out the fuser film and put some special high temp grease on the heating element, assembly all back and install, the other way is replacing the fuser unit
Mar 12, 2013 | Brother HL-2070N Laser Printer
Sir ,ir 2020 paper jam at fusing unit.some times half of paper will come out,sometimes jams at the entrance of fusing unit.i changed every sensors,then changed new fusing unit,then feeding assembly...
Sometimes you can vlear a fuser jam with a manilla folder. Open the copier let it coll a bit and slide a manilla folder through the fusing unit. If it is just pieces of stuck paper the folder can sometimes push them out of yhe wsy ad you gorce it through and pull it out the other side. The fuser has two rolls one heat and one pressure both of these rolls have small fingers which are supposed to kerp paper from sticking to them. Sometimes these fingers get bent or damaged and this causes the actual jam. There is also an exit sensor that detects jams in this area it can have a damaged part as well
Jan 20, 2018 | Canon iR 2020i Laser Printer
Hi I have a hp1015 prints ok but is crinkling the top right hand corner , after pulling it part where the heat roller is the part oppoiste it is braking part and this is the trouble item,.
Check the fuser unit.You have need disassembly and after reassembly the unit.Check and clean rthe upper fuser roller(heat roller and change the stripper pawls.After clean and reass. the unit verify that work manually easy,check the bearings and the plastic components(gears).
Aug 22, 2009 | Office Equipment & Supplies
H4-01
Dear sir h4 signal is fuser unite please you call a technician and solve your problem
Aug 12, 2009 | Sharp AR-507 Copier
Paper jam in fuser
Sounds like a timing jam, check paper supply, fanned, good quality, check and clean paper feed rollers.
Registration rollers clean?
If you are a tech, check and clean paper feed clutches, registration clutch. Check fuser for bearings, fuser drive, fuser roller cleaner or worn rollers.
Check exit sensor, is it out of place, is the actuator worn out, is the paper curling and coming off of the paper too early,
Try these, hope it is of some help.
Ed
Apr 23, 2009 | Office Equipment & Supplies
Phaser 6250
That problem is the registration clutch.
You have to order the registration assembly to get the clutch. It is located on assembly with the black and stainless steel roller, you have to pop out the imaging unit to see it.
But that WILL fix your problem. They changed the style of clutch also. It is more reliable now.
May 01, 2008 | Xerox Phaser 6250DP Laser Printer
What does j2 mean on a xerox work centre xd 100
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}H4 is a power failure code. To reset the errorplease press in the following order:
CLR - AUTO - CLR - AUTO
(this puts the unit in tech mode).
Enter 14 (as if asking for 14 copies)
Press "PRINT"
Your unit should reset itself and start working
Feb 19, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
69 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
