Question about Leisure Cookmaster CM101NR
I make cakes and I’m having difficulty in finding right temp in my new cookmaster ovens. Also the fan oven takes twice as long to cook things as my old one. Any advice would be appreciated.
Posted by Helen Amphlett on
cwcollectr
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 173 Answers
I believe all ovens cook differently i bought a professional davor unit and found things were cooking quicker then they should have. I kind of got use to it. I started using thermometers to keep a check on things. Found out they were cooking 10 minutes sooner. I set my timer 10 minute before and 99 % of the time their done. I had call a dacor technician come in and said there was nothing wrong with the unit.
Posted on Feb 05, 2019
ray gallant
    Top Expert:
  • Leisure Master
  • 67,943 Answers
Call a repair service locally , perhaps it is a minor adjustment they can make
Posted on Feb 04, 2019
5 Related Answers
Tony Coultrip
  • 183 Answers
SOURCE: Gas oven not heating to temp
The fault is either the capillary has fallen away from back or it is a faulty thermostat.
Regards
Advisor
Posted on Nov 17, 2007
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: uneven cooking in fan oven
There are many reasons for uneven cooking in any oven
These are just a few possibilities.
Not pre- heating oven
Putting too much in the oven, thereby restricting air circulation.
Not putting on correct shelf level.
Use of foil in the oven which can reflect heat.
Badly fitting door.
Perished door seal.
Thermostat not controlling temp properly. Check with oven thermometer.
There plenty of other resons besides these, but these are some of the more important ones.
So do check these points..
If you are still experiencing problems, then you will probably have to call an oven expert in too look at it.
Plz rate my solution
.Thanks.
Posted on Dec 17, 2008
Anonymous
  • 72 Answers
SOURCE: Neff U1524 Double oven
Your oven should be connecting individually to its own fuse in the fuse board.
Posted on Jan 04, 2010
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: i have a cookmaster 100 dual fuel the clock has
If the clock is not working, then that is the reason the main oven and fan are not working, as they go through the clock timer..
You need to get the clock working for the oven to work.
Hope this helps.
Posted on Jan 06, 2010
Anonymous
SOURCE: my oven takes ages to cook things am i missing
i have a 90 dfdo oven and it is not getting hot can you help
Posted on Oct 17, 2010
What temp do you cook cakes in if you do not have a fan forced oven
Different kinds of cakes require different temperatures. Most cookbooks tell you what temp to use for each recipe. Same goes for cake mixes. The instructions on the box are way smarter than me.
Mar 16, 2015 | Ovens
Kenmorw built-in oven (Model #30129) won't maintain cooking temp, flame is off and on continously, take twice as long to bake or broil food. If the temp is set for 500, the oven temp might be 250.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 06, 2011 | Ovens
I have recently purchased a Neff double oven UI722 and am experienncing difficulty with the heat control. Most things I cook seem to burn either at the sides or bottom or both . Can you help in any way...
It can be difficult to 'acclimatise' to a new oven particularly if it is a fan oven as cooking times are usually shorter.
Temperature distribution is also different so if you are following your normal cooking temp and time you may need to adjust these so as not to overcook.
Try a few set recipes from the hand book using the set times and temperatures to see if that makes any difference.
Good Luck
Dec 19, 2010 | Neff Ovens
I think the oven is not getting hot enough,i have baked three
Buy an oven thermometer to check if the temperature you set the oven at is accurate. You may have a faulty thermostat, but if the temp is only off by a little, you can calibrate the temp setting on the oven by as much as + or - 25 degrees. If you have an LCD screen, then most likely you can adjust it right on there. If not, then the backside of the oven knob can be adjusted + or -. by moving a set screw and turning as needed. Your owner's manual will have a more detailed explanation on this procedure. Douglas
Jun 13, 2010 | KitchenAid 30 in. Architect II Series 4.3...
Cooking temp to bake cake inn convection mode samsung model
Hi I guess you are cooking usng the combination setting? if so The cake will be hard due to increased microwave energy, I would suggest reducing the microwave energy on the Samsung unit when using the combination setting.
Hope this helps
Jan 07, 2010 | KitchenAid KHMC107BT Convection/Microwave...
I have a siemens combi micro oven, which is the best way to cook a christmas cake and at what temp
with the convection part at 325 deg, for 1 hour or less depending on the cake size..have fun cooking..
Nov 17, 2009 | Siemens HB77L55GB 900 Watts Convection /...
Oven - Failed baked goods, takes too long on other things
most ovens have what is called tempture sensor,its job is to read the tempture within your oven if this sensor is faulty then it sends the wrong signal to your display,you talk about a thermometer showing a different temp please do not put this thermometer in your oven some of these contain mercury and could explode in your oven.I would advise you to call a electrication and get him to test your tempture sensor.sorry i cant help you any better.adrian
Feb 12, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Seems to be taking a long time to cook
To preheat oven just select the temp you intend to cook at and wait until the red light goes out,it is then preheated
Then you can put your food in and carrying on cooking.
Yes you do put it on fan symbol, but make sure it is on the right one , as some ovens have fan only as well as fan and heat.
Plz rate this solution.
thanks.
Dec 14, 2008 | Ovens
Not cooking completely
replace the oven temp sensor. it looks like a probe that is in the oven, at the top
Jan 25, 2008 | Frigidaire FEF366DC Electric Kitchen Range
Leisure Cookmaster CM101NR Logo
107 people viewed this question
Top Leisure Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
Chuck Graybill
ray gallant
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
