Question about Golf
The ignition switch light comes on after using the cart for a a round of golf. What is happening?
Posted by Steve Petz on
Kardoc
    Top Expert:
  • Golf Master
  • 6,123 Answers
What type of cart are you using?
Posted on Jan 30, 2019
5 Related Answers
Anonymous
  • 24 Answers
SOURCE: I have a yamaha electric golf cart. The lights
I bet that it is an simple as a fuse that blown out. Try replacing the corresponding fuses.
Posted on Nov 07, 2009
Anonymous
SOURCE: club car golf cart won't start.
i have a 1989 club car 10 amp fuse is under seat in a box under air box should have one screw in center of lid
Posted on Mar 30, 2010
Anonymous
  • 6 Answers
SOURCE: i have a golf cart
http://i130.photobucket.com/albums/p271/bernsidecycles/shovel/install_hi4_new.jpg
Simple standard ignition switch diagram for Harley-Davidson Motorcycles, hope this helps!
Posted on Mar 02, 2011
Fran Mannone
  • 23 Answers
SOURCE: have 4 wires (red, green,
may i recomend to replace the switch rather than install a toggle. you have the wires exposed and maybe the switch out. it will be clean and preform better. Fran [mechanic]
Posted on Jul 08, 2011
fmkaguru0333
  • 4 Answers
SOURCE: step father tring to fix
Give me some more information about this problem. May be i can help.
Posted on Jul 15, 2011
We have a 1999 gas club car golf cart just replaced the ignition coil. It now won't turn off
You need to run a wire to the coil from the hot wire coming from your key/ignition switch. This will ground the coil and eliminate the spark.
Sep 02, 2016 | Golf
I'm not getting any spark out of the plug to start the club cart(1994)
Is this a golf cart? Single plug? Test for current getting to coil when ignition switched to ON. If yes, either bad ignition module or bad coil. If NO, check ignition switch and related wiring.
May 11, 2016 | Cars & Trucks
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Club car golf cart lights
Wiring, fuse and switch. Check for voltage at switch first, if none, check for a fuse in the circuit. I would suspect a fuse or faulty switch first.
Aug 20, 2014 | Golf
Yamaha Golf Cart won't start
did you leave the key on and kill the battery or a light or something double ck that battery , they will still light up the ignition and lights and ll but does not have enough to crank the starter , that is what is sounds like to me be put a jump on it or charge it and try again , when you turn on the ignition does the lights light up on the dash panal if so the batter is low
Mar 26, 2014 | Yamaha G-20 G20-g22 G-22 Golf Cart Tune Up...
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Mar 02, 2013 | Power Equipment Solutions 2002 Club Car DS...
How to wire a stereo into a G1 yamaha golf cart
all you need is a live wire which may be a switched live or a permanent live directly from the battery( switched live means the wire becomes live when you turn the ignition key) The chosen wire must be connected to theb radio via a 3 amp line fuse
Jun 26, 2012 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
I replaced the fwd / rev switch on my Club Car 1985
I recently replaced a F/R switch and just happened to write down which wires went where so maybe I can help. The front switch ( closest to front of cart) green/white wire to top contact, white/black to bottom.
Middle switch red/white to top, orange to bottom.
Rear switch green to top, black to middle and white to bottom.
Jul 27, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
Golf Logo
180 people viewed this question
Top Golf Experts
ray gallant
Kardoc
Bill Boyd
Are you a Golf Expert? Answer questions, earn points and help others
