Question about Alpine Car Audio & Video
SOURCE: Wire diagram
http://www.installdr.com/Harnesses/GM-Wiring.pdf
The top half of this pdf is for a factory stereo wiring diagram for models up to 1990.
Let me know if you need extra assistance.
Cheers!
Posted on Mar 21, 2009
Large Blk and Large Wht goes to 2a
Large Red goes to 1a
Grn goes to 1b
Blu goes to Bz
Coax goes to Vd
Wht (shielded) goes to Gs
yel goes to 33
Red Shielded goes to Bp
Brn (small) goes to pl
black shielded goes to tI
Large brown not used tape end fold back and secure to harness.
Posted on May 04, 2009
SOURCE: Ribbon cable connecting screen for LG KS360 needs replaced.
http://www.formymobile.co.uk/ks360disassembly.php
this link shows the full dissembly of the phone and shows the ribbon cable in stage 6
Posted on Sep 05, 2009
SOURCE: '04 Nissan Sentra S factory installed subwoofer wiring diagram
A FACTORY INSTALLED AMP/SUB WILL BE WIRED INTO THE VEHICLES FACTORY WIRING JUST AS ANY OTHER COMPONENT. YOU WOULD THINK THAT YOU WOULD FIND THICK POWER AND GROUND CABLES ALONG WITH RCA CONNECTIONS AS YOU FIND WITH MOST INSTALLS.NOT THE CASE HERE.YOU MUST FIND THE HARNESS THAT HAS THE POWER AND GROUND CONNECTIONS ALONG WITH THE INPUT WIRES FOR SOUND. YOU MUST OBTAIN A VEHICLE SPECIFIC WIRING DIAGRAM THAT HAS THE WIRING FOR THE SOUND SYSTEM PACKAGE THAT CAME WITH YOUR VEHICLE. YOU MUST THEN WIRE IN THE BLUE REMOTE TURN ON LEAD FROM YOUR UNIT TO TURN THE AMP AND SUB ON WITH YOUR RADIO AND NOT YOUR CAR BATTERY. YOU WILL ALSO NEED TO FEED SOUND TO THE AMP USING ONE OF THE REAR OUTPUTS FROM YOUR RADIO.
Posted on Sep 08, 2009
SOURCE: need a diagram for wiring trying to trace wiring
Heres a wiring diagram for the fuelpump.
Posted on Oct 04, 2010
