Question about Candy Dryers
I DON'T KNOW. I JUST REPAIRED A WASHING MACHINE THAT WAS 'DEAD'. IT WAS THE LID
SWITCH. THERE WAS A PLASTIC POINTER THAT
FIT IN A HOLE TO TOUCH SWITCH WHEN LID WAS CLOSED. GOOD LUCK WITH THAT.
Posted on Feb 10, 2019
SOURCE: dryer cutting main power off after acouple of seconds
you need to ck the back off the dryer and open the small cover wher the elet cord is ateched . it may bo loose or need to replace the block.
Posted on Apr 14, 2008
SOURCE: Zanussi TC485W condenser tumble drier
If your dryer has been fine for sometime and then failed you probably need tech service for a replacement element or motor. Or should you feel qualified, run down the power to your drier including your ground. Your ground wire should NOT be connected to a water pipe. It must be directly connected to your main circuit panel. Then do this. Check for a high load on your motor. If you don't have any then it is shorted in the wiring. That are all the major working parts to your dryer or any dryer. The timers wouldn't cause this.
When a dryer element is carrying a proper load the circuit physics are correct, when the burn out it acts like a direct short and will pop your breaker or will not dry at all. The same is true for your motor. The wiring inside the motor can overheat and the varnish on the wiring wrappings can melt and short.
Regards,
Worldvet
Posted on Jun 15, 2008
SOURCE: Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Posted on Oct 12, 2008
SOURCE: hoover condenser tumble drier keeps setting off
Poss. element fault , going to earth , call service agent to check.
Posted on Nov 09, 2009
SOURCE: i have a white knight
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 21, 2011
