Service provider says unit needs a blower motor and capacitor. Estimated delivery at end of march - not an option! Wants to sell me a new unit. any suggestions on where to get the motor or one that will work with the unit?
SOURCE: Replacing a blower motor on a TRANE unit
Look on the motor it self or website that motor.! Thank -you-very-much!
SOURCE: Samsung DV337 Dryer; the motor runs but the tumbler not turning
you need to remove the top of the dryer first then remove the control panel. then all the screws from the front panel then you can look inside and see what is going on
SOURCE: range hood blower motor - rangemaster
I'm not sure if it a regular home range hood but if it is. Check the price of a new one. A regular home range hood cost around $100.00 and a fan motor runs around the same. If it a commercial type is another story. If commercial Heritage Food Service Equipment will have the motor.
SOURCE: Carrier 58 Series Furnace Blower Motor Won't Shut Off
Yes. If the high limit is tripped, the furnace will bring on the fan continuously until the limit resets. Often, they will not reset if tripped repeatedly. If the furnace is too large for your application, you probably are not able to move enough air to keep the heat exchanger cool enough.
SOURCE: I have a Carrier Weathermaker 8000 VS furnace that
If you can get to the shaft of the motor, oil it using electric motor oil. If the motor spins freely, you just may need to replace the start capacitor, however if it is binding; you will need to replace the inducer as an assembly.
