Question about NEC Computers & Internet
How to make wifi extender through nec atren wm3500r in home wifi?
Posted by mohit tanwar on
DADA BHAI THAKUR
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 77 Answers
Firstly, check for reset button on your WiFi extender, press and hold for few seconds till all lights off.
Search for WiFi SSID and connect your laptop or mobile, browse for given ip on extender in browser, give it's password and follow the wizard to complete setup.
Posted on Jan 29, 2019
  • DADA BHAI THAKUR
    DADA BHAI THAKUR Jan 29, 2019
1 Related Answer
josh_and_mi
SOURCE: Can you please tell where
No luck,
The Wimax modem you are trying to get a manual for is only currently being widely used in Japan I believe.
It's a good unit and pretty easy to set up even if you don't read Japanese. The easiest way is to make sure there are no other wi-fi networks around and then access it via wifi. Most modern operating systems will automatically detect it and you'll need to enter in the AES password on the back of the unit wear it says (AES) lots of spaces than colon than the password. Or if you try to access it on a portable device you may have to enter in the WEP password. (there will be two networks autodetected probably and each network is a different type and has a respective password)
Once you have done this you still won't have internet. You have to type in http://web.setup/ in the internet browser of the device you are using. If nothing happens try the other network with the other password above. If still nothing happens then try entering http://192.168.0.1/
Once you have successfully done this you'll be prompted to put in a user name an password. Use the user name "admin" with some password several times until you get prompted to enter a new one and then again below.
You'll need a Japanese friend to help you with the rest.
Good luck
(and it's better to not use an iphone/ipad etc.. or you may end up in a weird refresh loop (if this happens close the window in safari and exit and try again with "admin" and your new password.)
Posted on Sep 11, 2011
We do not have an Ethernet socket on our computer please advise
Plug the extender into the electric socket in your home.
Whatever your router name is needs to be set up on your router and the words added to the end of your wifi name. _EXT.
I set mine with the same password as my normal wifi and saved it so it automatically finds the Extender unit.
Whe
Jan 02, 2015 | Computers & Internet
Www mywifiext net
1-888-939-9092 is Netgear support. I have used them many times in times in the past for help. Give them a call and they might help configure it for you.
Jul 17, 2014 | NetGear WN3000RP Universal WiFi Range...
How to set up netgear ex6100 wifi range extender
Overview:
This article describes how to set up a NETGEAR EX6100 in Extender Mode
The extender connects wirelessly to your existing WiFi network, and then it creates a new WiFi extended network and links the two WiFi networks.
Symptoms:
Cannot connect to extender
Extender broadcasting EX6100_NETGEAR_2GEXT
Extender broadcasting EX6100_NETGEAR_5GEXT
Extender cannot access Internet or network
Process:
1. Place your extender in the same room as your WiFi router.
2. Plug the extender into an electric outlet and wait one minute.The PowerLED lights green.
If the Power LED does not light, press the Power button on the side.
3. Make sure that the mode switch on the extender is set to Extender.
4. Use a WiFi network utility on a computer or mobile device to find and connect to the EX6100_NETGEAR_2GEXT or EX6100_NETGEAR_5GEXT (SSID) WiFi network.
Note: EX6100_NETGEAR_2GEXT and EX6100_NETGEAR_5GEXT are the default name of your extender's wireless networks, and by default it is unsecured. If you changed the wireless name or security in the past, connect to the new name or enter the passphrase when prompted. EX6100_NETGEAR_5GEXT is only visible if your wireless adapter is 5 GHz capable.
After the wireless connection with the computer or mobile device is established, the Client Link LED lights solid green.
5. Open a web browser window from the same computer or mobile device.The browser takes you directly to NETGEAR genie Smart Setup.
Note: If you are not automatically directed to NETGEAR genie, launch an Internet browser and type www.mywifiext.net in the address field of the browser. Enter admin for the user name and password for the password.
6. Select a 2.4GHz WiFi network to extend and click the Continue button.
7. Type the network passphrase (also called password or security key) in the Passphrase field and click the Continue button.
8. Repeat steps 6 and 7 to select a 5GHz WiFi network.
Note: If your router does not support the 5GHz band, click the Skip button.
9. Select Private Network(home network) or Public Network radio button, and click Continue.
Note: Selecting Public Network will enable NAT and DHCP on the EX6100. For more info on NAT refer to: What is NAT (Network Address Translation)?
10. Type the name (SSID) for your WiFi extended network in the 2.4GHz and 5GHz Network Name (SSID) field and click the Continue button.
Note: You can use the same security settings as your existing network by selecting the Use the same security mode check box.
The WiFi extended network settings are applied.
11. Use a WiFi network manager on a mobile device or computer to connect to the extenders newly created WiFi network.
12. Click on the check box and click on Continue to finalize the installation.
13. Unplug the extender and move it to a new location closer to the area with a poor WiFi signal.
Note: The location you choose must be within the range of your existing WiFi router network.
14. Plug the extender into an electrical outlet and wait one minute. The Power LED lights green. Connect to the extender network and enjoy the extended Wifi network.
May 02, 2014 | Computers & Internet
Nec lavie cant connect to wifi
You can download the device drivers from the NEC WEB site. Please click on this link and select your model computer/notebook and the Windows drivers you require :-. www.nec.com/global/support/downloads/index.html
Mar 05, 2013 | NEC LaVie S LS900/8E Notebook
How do I get my wireless from one end of thr house to the other
Yes with a wifi router extender like http://www.netgear.com/home/products/wireless-range-extenders/
Dec 03, 2012 | Computers & Internet
My laptop has limited internet access. I've called up my router provider and they said theres nothing wrong with the router as it works fine on all other laptops in my house. I have a sony vaio, I have...
Hello -
Depending upon where (in your home?) you use your Sony Vaio laptop (via WiFi?) you may need a WiFi booster or extender. Or, you may find that moving your WiFi router to another location in your home will improve your connection without diminishing the connections for other laptops used in your home.
Perhaps the information here will prove instructive:
https://www.repeaterstore.com/pages/wifi-booster-repeater-extender-differences
Note: If the router needs to be moved in your home, you will probably need a technician for your Internet provider to come to your home to relocate it and connect it properly.
Dec 28, 2017 | Sony VAIO Computers & Internet
Computers & Internet Logo
46 people viewed this question
Top NEC Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
