Question about Element Electronics Televison & Video
My Element tv power light comes up but nothing else the screen flashes element once and goes back out
I have tried the power down or whatever it is called by unplugging the tv holding the power button in and then plugging it back in holding the power button 45 seconds still nothing
5 Related Answers
Anonymous
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Posted on Jul 18, 2007
tiafau
SOURCE: 42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Posted on Oct 07, 2007
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: Sansa E250 Black screen lighted wheel, wont do nothing else.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
ABRsvcs
  • 4234 Answers
SOURCE: TV won't turn on, delay/timer light flashing
Please update this with the blink count. That will indicate the circuit in which a problem was found. Once I have that information I should be able to give you the probable cause and remedy.
Dan
Posted on Dec 02, 2008
Anonymous
SOURCE: no video or sound, just blinking power light
make sure tv not in standby mode
Posted on Jan 25, 2009
Element tv was working fine now get a pink screen only. Turned tv off for 2 minutes and tv worked fine then shut off and now power light flashes from bright to very dim. Tv won't come on now ????¿?
Sounds like power supply has fried, take to TV repairman or since its an Element just buy a new one that is not an Element. Get a LCD, LG is good.
May 30, 2016 | Element Televison & Video
Element T.V. modelELEFW504A,I replaced the main board/power supply when I turn it on it flashes oncs screen is dark no sound,fixes?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
May 20, 2016 | Element Electronics Televison & Video
Element flat screen tv screen appears off when power is on
At this stage, try replacing ps Caps. Old elements had cap problems in ps area.
Feb 11, 2014 | Element Electronics Televison & Video
FLX3211b when plugged in the red power light comes. Then when the TV is turned the red light turns blue and stays on. The Element logo appears for a couple seconds then the screen goes black. There is a...
the transformer for the backlight is usually what fails on the elements especially if the logo comes up briefly then the screen goes out. I would check the transformers.
Apr 04, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Element tv.. model # ELCHS261 stopped working
My Element ELCHS261 will not turn on at all. The only thing it does is the red light will turn to blue but no sound and no picture. My troubleshooting items have been changed the batteries in the remote then I unpluged the power for for 30 minutes and still nothing.
Jul 10, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Element flx-3210 lcd tv
I have an element lcdtv 32inch. The tv is less than a year old, i was watching the tv and it just shut off. The red light is on, when i go to power it up, the blue light comes on for a second then blinks, and goes back to red. I know its not a brand name tv, but for 600 bucks, it should last for more than 8 months. Anyone have any advice ?
Feb 24, 2008 | Televison & Video
Televison & Video Logo
80 people viewed this question
Top Element Electronics Televison & Video Experts
Mike
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
