SOURCE: I just bought the Vizio
Make sure its all hooked up right two wires switched could throw off the speakers
SOURCE: I Have a 5.3 IR
lojr, (VCR button instead of TV button)
We have code to use with amplifiers, TVs, VCRs, and DVD players. I do not have a code that will work on this sound bar. What is the code you are trying to use? Did Vizio supply a code with your sound bar. They do have codes to use for their TVs to program DISH remotes. Please let me know if you have a code or you can contact Vizio to see if they have a code available.
I have provided the Power Scan instructions on programming the remote to a sound bar. Use the VCR button to attempt to program the sound bar.
If you have further questions, please post it here.
Ray Calo
DISH Network - Executive Offices
Power Scan Instructions Power Scan Instructions
1. While at the sound bar location, point the remote
at the sound bar. Press and hold the VCR MODE button on the remote until all four MODE
buttons at the top of the remote light up.
2. Press the RECEIVER POWER button on the remote.
3. Press the UP ARROW on
the remote, about one press every two seconds. Stop as soon as the sound bar turns
off. This process may take several minutes.
4. Press POUND (#) on the remote. The VCR MODE button will
flash three times.
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press
VOLUME on the remote to confirm the remote controls the sound bar. If this does not
work, return to Step 1.
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
SOURCE: I recently bought a Logitech Harmony One universal
Great remote but not always easy to find right category for device.
Had a look for you and sure enough the device IS listed in data base under AMPLIFIER- then select amplifier again and input vizio for make and soundbar for model and click next.Problem solved!
SOURCE: new vizio tv and vizio
get to your menu on the tv and click your audio, go down to speakers and turn it to the off position.
SOURCE: how to connect a laptop 3.5mm audio out to a Vizio soundbar
You need a 1/8" stereo jack to rca....can get on at walmart....hook it from your headphone jack on your pc to the input on the sound bar....input 1 or 2....make sure you have the right iput selected for the sound bar and you should be in business
Testimonial: "yes!!!"
