Question about Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr Savona has blue blinking light. What does that mean?
Posted by Elvira Mariscal on
Mark Anthony Canete
    New Friend:
    Problem Solver:
  • 9 Answers
The fan light switch blinks when it is time to clean the filter. Clean the filter, then press and hold the switch for 3 seconds to reset it.
Posted on Jan 30, 2019
5 Related Answers
Anonymous
SOURCE: Zephyr Savona Range Hood only speed 3 works
had same problem (w/in a few months)
switch assembly poor design
thay sent a replacement (i put it in)
seen other complants
Posted on Jul 20, 2008
HandyTxDude
  • 37 Answers
SOURCE: need to change lightbulb of Zephyr Savona Zsa-m90s
I'm not sure if my Savona is the same one, but on mine, just remove the filter and you can see the base of the light bulb up above the fan base. You can see where the bulb screws into the fixture. Grab the ceramic portion of the bulb, and turn that part. You may want to steady the socket with your other hand because it is very flimsy.
Posted on Jan 03, 2009
Anonymous
SOURCE: light blub burnt out
The easiest way to remove the light bulb is to wear a rubber glove, use your palm to press against the bulb, and turn counter-clockwise.
The suction created by the rubber glove should allow you to remove the light bulb easily.
Posted on Jan 15, 2009
Anonymous
Original bulb is actually a JDR--I purchased 2 bulbs and received JDRC bulbs that are shorter and do not fit and there is no adjustment at the bulb housing/socket--LOL
Posted on Apr 07, 2009
Anonymous
  • 121 Answers
SOURCE: Zephyr Savona range hood quit work on low spds-hi still works
Motor Speed may not be working and this means the either the motor is bad or switch is bad for motor Low Med Hi Switch
Posted on Jun 02, 2009
My Zephyr hood model zto-m79s lights don't work. The unit was installed in 2007. Sometimes they sputter, flashing briefly, then nothing. Do I need a service call or can I fix it myself? Nancy
Try taking out the bulbs and wiping with a clean dry cloth. Sometimes when bulbs get hot the connection loosens, when you screw them back in do not over tighten.
Replace fan/light switch zephyr pyramid range hood
I am also looking for instructions for PLHV36W6CC.
The fan is on right now but the switch is sliding back and forth loosely.
I just downloaded the manual but that was no help.
If someone has a quick solution, that would be great.
Please email me at [email protected]
I have stuck my hand up and fiddled around but besides just ripping it out, could use some help.
Thanks,
Robert
www.150FastGroup.com
3helpful
2answers
Range hood is making noies
use a good 3 in 1 oil. Don't use WD-40 it will only clean it then dry out the bearing. the problem will be worse than when you started.
3helpful
Light blub burnt out
4helpful
Need to change lightbulb of Zephyr Savona Zsa-m90s
Push Button Switched
zepher sent replacement sritch.
had to wait a while -parts from italy (heh)
so far ok
design is poor
Zephyr ZMI-M90S stopped working
The company doesn't list such a part. Probably, you have a bad connection in the unit. With the power off, remove the motor housing. Find the connection box and fix up the connections.
Zephyr Savona ZSA-M90S Kitchen Hood Logo
Top Zephyr Kitchen Ranges Experts
Vish Iyer
Vish Iyer
Dale Copeland
Dale Copeland
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
