SOURCE: Coleman 1500 power inverter has no output
I believe that the actual unit may have other problems and that you will need a schematic to aid in your troubleshooting of this issue. Once you have the schematic and a multiment you can check the voltages to see if things ar as they should be and then we can look at what is happening.
SOURCE: Battery and Charger problems
I have to agree with the previous commenters who called the support line- I was off the phone in less than 5 minutes with a new battery shipped free of charge. 1-800-435-7732
Congrats casio- I'm buying my next one from you too.
SOURCE: charging indicator stays red
Hmmm...is
the USB cable plugged in to a powered PC? Could be cable or battery
issue. Red light means that the battery is very low on juice. Return it
to where you got it from if you can't solve it on your own.
you want a repair service
SOURCE: In the Coleman 5312 Retro Series Lamp is it
Brentonb, In the event that you don't get a direct answer (which is likely, since this is a pretty obscure question) I suggest you troubleshoot it this way. Remove the bad battery. Use the charging device that came with the lantern and wire it temporarily to the device in place of the battery. This will supply the correct voltage, but takes the possibly shorted battery out of the circuit. If you are certain you have the polarity correct and you know that the charger works, then you have your answer. good luck.
