Question about Taylor Measuring Tools & Sensors
My Taylor Thermometer NSF model # 9848EFDA is stuck on low. Ive tried changing battery and this does not work. What else can be done?
Posted by Patty Scott on
5 Related Answers
alicantecoli
Colin Stickland
  • 22485 Answers
SOURCE: my truck is stuck in 4 low
get underneath and check the switch on the gearbox
Posted on Mar 12, 2010
Anonymous
SOURCE: how do you replace the battery on a Taylor 508
1) remove the soft rubbery cover from the back of the thermometer, this will expose a screw which holds the front plate on. 2) remove the newly exposed screw 3) use a knife or screwdriver (in the small slot on the side of the thermometer) to pry the two pieces of plastic case apart. This will expose the battery 4) use a screwdriver to remove the 1 screw holding the battery cover to battery. 5) replace with a CR2032 3V Lithium cell 6) replace screws and covers
Posted on Dec 18, 2010
breezyken
breezyken
SOURCE: Taylor 1542 wireless thermometer - how to install remote batteries
Flip up the curved cover latch and then pry open the top of the battery compartment cover with a long fingernail, small screw driver or coin. I agree it could be easier.
Posted on Jan 24, 2012
drifter
SOURCE: I have a Taylor Mini Remote Thermometer Model
The alarm is a freeze alarm, it's a extra option, included at no charge, but only on channel 1.
Change to another channel, and it will be gone.
Posted on Oct 12, 2012
hansonmg
The Vanguardian
  • 531 Answers
SOURCE: second request re: taylor lithium electronic scale model 7000 not working after changing battery twice. Yes interested correctly
On Amazon this scale got 24% 5 star and 43% 1 star rating.
In many cases it quit working or broke in some way.
"I owned this model for 1 year before it gave me the "batt" signal. after I spent another $7 on new lithium batteries, it turned out the scale was broken. looking on the web, I discovered lots of other stories like mine. advice: find another brand."
Posted on Aug 03, 2016
How can i stop the taylor 1341 digital thermometer from beeping.
remove four screws on back of unit,cut red wire going to round beeping speaker inside lower front faceplate. problem solved it will never beep again but still read temp correctly.
May 19, 2014 | Taylor 1431 Digital Wireless Thermometer
Installed new batteries, but need instruction to reset temperature readings
Type "Taylor 1524 manual pdf" in google. That should pull up your manual. Sometimes companies produce the same item, with just subtle changes (product differentiation) i.e. Chevy used the same motor block for the 327,350,400 chevy motors, and just installed different cylinder heads.
Apr 22, 2014 | Taylor 1524 Wireless Indooroutdoor...
My taylor 1525 thermometer does not display or not working
I've just been through this with my Taylor. My first mistake is that I put the batteries in the wrong direction... I corrected that and it only worked for a short time, then quit.. Ultimately, I had to get my multi-meter out. I found that one of my batteries was faulty.. Now, you have to remember that there are two AAA batteries in the main unit... and two of them in the remote that you place outside... Go.. You can fix it...
Jan 16, 2013 | Taylor 1525 Wireless IndoorOutdoor...
Jan 14, 2012 | Measuring Tools & Sensors
Taylor Wireless 1542 remote batteries how to install
Remove the 4 small phillips head screws on the battery cover and it lifts off.
When you replace the cover make sure the gasket (black rubber) is in it's groove.
Jan 14, 2012 | Taylor 1431 Digital Wireless Thermometer
For taylor scale model 7075. How do I fix error code 6aee
I know what is this error. This is BATTery low. New battery last only 2 month, I've seen a problem with the kick feature to power-on the scale, those pressure buttons might get stuck and leak current and kill the battery.
Aug 29, 2010 | Taylor 7506 Precision Tech Lithium Battery...
Measuring Tools & Sensors Logo
467 people viewed this question
Top Taylor Measuring Tools & Sensors Experts
deton8 von Splosion
Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
