SOURCE: My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
SOURCE: kitchen aid open door sensor alarm keeps going off door is closed
Open door and turn power off then on twice. Then press the Overtemp reset.
SOURCE: Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
SOURCE: I have an fisher and
Hi and welcome to FixYa, I am Kelly Diagnostic Mode To enter diagnostic modes, press and hold the MENU button - then press the UP button for 4 seconds. The PC temperature will be displayed on the LCD. The actual temperature of the PC is shown. Note Temperatures are shown in Degrees Centigrade. PC Sensor Temperature ____ - By pressing the Up button once more, this will indicate the FC sensor temperature. Note: The "min" indicates minus 12°C FC Sensor Temperature - By pressing the Up button once more, this will indicate the Defrost sensor temperature. Defrost Sensor Temperature - By pressing the Up button once more, this will indicate the input/Output Status. Input/Output Status - Press UP one and two more time, both LCDs display 87.5 but should be ignored Spare/ Blanks - Press UP one more time and fault history will be shown. Fault History To exit diagnostic mode press MENU button FAULT CODES: A wrench symbol and LCD fault code will appear automatically if there is a fault in the temperature measuring system, defrost system, fans or low ambient heater. When the PC door is opened an alarm will sound, the number of beeps also indicates the fault code. Pressing any of the control buttons can deactivate these alarms Fault Code 1 Reason: On last power up, the power module failed self test. Primary Action: Replace power module Fault Code 2 Reason: The previous 2 defrosts were aborted after 30 minutes Primary Action: Check defrost element Fault Code 3 Reason: The resistance of all the temperature sensors is outside the normal range (>45K Ohms) Primary Action: Check 6 -way Rast connector at power module Fault Code 4 Reason: The resistance of all the temperature sensors is outside the normal range (
Primary Action: Check 6 -way Rast connector at power module Fault Code 5 Reason: The resistance of the FC sensors is outside the normal range (>45K Ohms) Primary Action: Check sensor connector at power module Fault Code 6 Reason: The resistance of the FC sensors is outside the normal range (
Primary Action: Check sensor connector at power module Fault Code 7 Reason: The resistance of the Defrost sensor is outside the normal range (>45K Ohms) Primary Action: Check sensor connector at power module Fault Code 8 Reason: The resistance of the Defrost sensor is outside the normal range (
Primary Action: Check sensor connector Fault Code 9 Reason: The resistance of the PC sensors is outside the normal range (>45K Ohms) Primary Action: Check sensor connector Fault Code 10 Reason: The resistance of the PC sensors is outside the normal range (
Primary Action: Check sensor connector Fault Code 11 Reason: The current for the LAH, PC &FC Fan is lower than expected Primary Action: Check the 6 way fan/LAH, connector at module. Fault Code 12 Reason: The current for the LAH, PC &FC Fan is higher than expected Primary Action: Check the 6 way fan/LAH, connector at module. Fault Code 13 Reason: LAH is drawing less current than expected. Primary Action: LAH open circuit Fault Code 14 Reason: LAH is drawing higher current than expected. Primary Action: Check wiring connection Fault Code 15 Reason: PC fan is drawing less current than expected. Primary Action: PC fan open circuit Fault Code 16 Reason: PC fan is drawing higher than expected current Primary Action: Check fan wiring or connections Fault Code 17 Reason: FC fan is drawing less current than expected. Primary Action: FC fan open circuit Fault Code 18 Reason: FC fan is drawing higher current than expected. Primary Action: Check FC fan & wiring circuit Thanks for choosing FixYa, Kelly
You should enter the diagnostic mode to determin your fault:
There are also Ice maker faults that are NOT included above. This should get you started and if everything passes above diagnosis the problem is most likely in your ice maker circuit. The reason I did not include ice maker faults is because they do not cause alarms.
SOURCE: Door alarm light is on
The open door alarm is triggered by the small switch that also triggers the internal lighting. This is easy to test: open the door and press the switch - on a normal one the light should go off.
This is the switch
http://www.bizrate.com/refrigerator-accessories/oid1852839097.html
And here is in the parts manual page 4 part 14
ftp://ftp.electrolux-na.com/prodinfo_pdf/stcloud/5995552030.pdf
