Check for corrosion in battery area, contacts, etc.
If you like using the camera then it will be easier to get a replacement body rather than getting it fixed. 1 hour of a camera tech time is worth more than the camera. Have a look on ebay.
You could also just sell it to a collector or for spares as 'non working' on ebay.
The lenses might be worth something but wont fit modern EOS camera.
SOURCE: Canon A95 gone dead
I ain't so lucky I'm in the UK too!!!! Generally speaking the cost pf packing, shipping repair, at any level is well on the way to the price of the next more recent higher specification device. Judging by the way the Megapixels go up by the week seemingly, settling for a replacement camera is usually the best option. I had a cheap[old] Fuji come my way because it had gone blurred and blue - sure sign of a CCD failure as this was at some time the subject of a recall for the problem I checked out Fuji Their response was to say no longer repaired but has a 1/3 off a new camera when I quoted a reference number. That seems to be the way to go.
SOURCE: Is our Canon T70 dead?
It sounds like the motor is locked up. The gears under the bottom of the camera may have gotten sluggish from dried out lubrication. You can take the bottom off to see if the gears are able to turn freely or check with a local camera repair shop.
CameraRepairs
SOURCE: Powershot A430 canon camera battery problem
Alkaline batteries just don't have the power for more than a few pics in a digital camera. Some may have reached their shelf life, and though brand new may even have problems just powering startup of the camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. Retailers sell these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
SOURCE: Low Batterie Sign
I had the same prolem. OK, try this. Try to discharge the AA batteries in some use, flashlight or else,,,,then recharge them, full charge, install the batteriers ...they should work fine....
I read somewhere that canon is able free of charge to correct a shortcircuit that the camera is susceptible to develop in the installation of batteries......But I hope the advise will work...
Remove batteries when not in use.
SOURCE: Canon A460 problem
I have a Canon A460 and the only red light I know of is the auto-focus light. If it's a low battery you'll see the indicator on the screen, not a light.
