Computers & Internet Logo
P
Patti Gre Posted on Jan 27, 2019
Can I rename my Smart Plug devices? If so... how?
2answers
What is the process to connect the Smart Plug to Alexa Device?
check this video https://www.youtube.com/watch?v=DxVcU2fCaTI
Why is my Alexa isn't discovering devices?
Your Smart device is not compatible with the Amazon Alexa device
Smart Device is not connected with same Wi-Fi network
Alexa Device Firmware not updated
Alexa Skill did not update or Added
Amazon Alexa not mention or add the Rename your Device
Read more: Alexa Not Discovering Devices
Alexa Drop In
How to Fix the Connecting issues with Alexa to smart Plug?
Smart plug used with the wall outlet to control your home devices with your Smartphone. So here we mention How to Connect a Smart Plug to Alexa device as follows 6 Steps.
Step1: Firstly need to plug the Smart Plug in the outlet wall
Step2: Now then setup Alexa App with Smart Plug
Step3: In the thirds Step you can connect the Smart Plug to the Alexa App account
Step4: After do, add the Alexa to Smart Plug and wait for setting Up the Alexa process
Step5: Then, pair through the Alexa and Smart plug through skill store
Step6: If any is needed then you can get help through Alexa expert.
During connecting Alexa App or smart plug internet connection are working situation with high-speed data otherwise Alexa won't connect to Wi-Fi problem or Alexa offline issues create.
1helpful
How do I rename a device on Lifestyle T20
You have rename the device itself, throught the settings on the actual device.
How do i rename a contact n whatsapp
Rename in phone contacts then refresh the watsapp or restart the app
6helpful
Manual configuration of my "MY
Manual Configuration for Globe Subscriber:
GPRS Settings
GPRS Data Account 3 Account Name: myGlobe MMS Access Point Name (APN): mms.globe.com.ph GPRS Data Account 4 Account Name: myGlobe GPRS Access Point Name (APN): www.globe.com.ph WAP Network Settings
Rename Profile: myGlobe WAP Homepage: http://www.globe.com.ph/globe.asp Data Account: myGlobe GPRS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
MMS Network Settings
Rename Profile: myGlobe MMS Homepage: http://192.40.100.22:10021/mmsc Data Account: myGlobe MMS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
Manual Configuration For SMART subscribers:
GPRS Settings
GPRS Data Account 1 Account Name: Access Point Name(APN): GPRS Data Account 2 Account Name: SMART GPRS Access Point Name(APN): Internet Exit and save settings WAP Network Settings
Rename Profile: Smart WAP Homepage: http://wap.smart.com.ph Data Account: Smart GPRS Connection Type: HTTP Proxy AddressL: 010.102.061.046 Proxy Port: 8080
Rename Profile: Smart MMS Homepage: http://10.102.61.238:8002 Data Account: Smart GPRS Connection Type: HTTP Proxy Address: 010.102.061.046
Jun 27, 2011 • Cell Phones
How to name cruzer 4GB Stick?
Renaming the USB device is very simple.
-Plug in the USB device into your computer
-Go to Computer or MyComputer and you should now see the USB drive listed their under a drive letter like F: or G
-Right click and select Rename
-Name is whatever you like!
Regards,
G33k
3helpful
2answers
Lost instructions need to know how to download pictures to cruzer micro
USER MANUAL LINK
Copying to or from a USB device is the same as copying to or from any standard disk device.
1. Click on your desired file to select it.
NOTE: You can select multiple files by holding down the Ctrl while left click on the desired files. Or you can select all files by holding down Ctrl and press A.
2. On your keyboard, hold down the Ctrl key and press C.
3. Navigate to the desired folder destination.
4. Hold down the Ctrl key and press V.
U3 smart drive is a USB flash drive that allows you to install and run U3 smart applications from the U3 smart drive itself. When you use a drive in this manner, you can take your applications with you and run them on any Windows 2000 or XP computer.
Not only can you use the U3 smart drive for carrying your files but you can also carry your applications with your personalized settings with you as well. There is an application that is included on every U3 smart drive called the U3 Launchpad and it is your console for managing the applications that are installed on your U3 smart drive. The U3 Launchpad also provides utilities that let you customize your U3 smart drive your way.
More on U3:
Under the hood, a U3 smart drive is an advanced USB flash drive with special features that allow the U3 smart drive to take on multiple personalities depending on how it has been configured. The default configuration is composed of two drive letters or domains. One of the drive letters is a removable mass storage domain just like any other USB flash drive. The other drive letter or domain emulates a closed CD-R CD disc in a CD drive and contains the U3 system files that makeup the U3 Launchpad. When you connect the U3 smart drive to your PC, you will see two new drive letters after the Windows OS has fully set up the drive.
You will see the emulated CD-R drive which usually is indicated in file explorer by a U3 logo and another drive letter that is the mass storage domain. The mass storage drive letter will have a label with a name like "My U3 Drive" or some other manufacturer specific label. Newer versions of the U3 Launchpad lets you rename the drive letter label using the Status and Settings dialog. Older U3 Launchpads can be renamed by right clicking on its drive letter label in file explorer and selecting rename.
The drive letters assigned to the two drive domains by the Windows operating system can be any available letter but typically are between F: and Z:. The two letters may or may not be sequential and the mass storage drive letter may be before the CD-R drive letter. You do need to see both drive letters appear in order for the U3 Launchpad to run.
2helpful
I have Aspire 4730Z acer laptop. but can't install blue tooth. when going to install driver from utility CD showing no device found. let me clear how can I resolve the problem
Method 1: Rename the Bth.inf file loadTOCNode(2, 'workaround'); Rename the %WINDIR%\inf\Bth.inf file to Bth.bak before you install or reinstall the third-party device or stack. When you rename the file, you prevent Windows Plug and Play PNP from using that INF file to install the Bluetooth driver that is included with Windows XP SP2. To rename the file, follow these steps:
  1. Click Start, click Run, type %windir%\inf in the Open box, and then click OK.
  2. Right-click Bth.inf, and then click Rename.
  3. Rename Bth.inf to Bth.bak, and then press ENTER.
  4. Install the third-party Bluetooth driver.
Method 2: Update the Bluetooth driver in Device Manager loadTOCNode(2, 'workaround'); To replace the Windows XP SP2 installation of the Bluetooth stack, update the driver in Device Manager. When you do this, specify your third-party driver. To update the driver in Device Manager, follow these steps:
  1. Click Start, click Run, type devmgmt.msc in the Open box, and then click OK.
  2. Locate the device.
  3. Right-click the device, and then click Update Driver.
  4. Follow the steps that appear on the screen in the Hardware Update Wizard to specify your third-party driver for the Bluetooth device.
Top Smart Computers & Internet Experts
vince
Paul Bade
Are you a Smart Computer and Internet Expert? Answer questions, earn points and help others
