Question about GE Refrigerators
Adora side by side. Why does it make a noise like a door flapping?
Posted by Dealonnia Alberson... on
5 Related Answers
Vish2
Vish Iyer
  • 75 Answers
SOURCE: GE Adorda dishwasher
This one is a known issue and an easy fix. Use a tie wrap to securely tie the water tube for the middle spray to the upper basket. That's it. Believe it or not, it's that simple. You may want to secure it at the front and the back. To test this you can use the tie wraps used to closed the plastic grocery or bread bags. If this solves the problem you can buy a bag of nylon tie wraps from any hardware store. I had a similar problem with another GE model with a similar problem. The dishwahser used to make a horrible grinding noise during the wash cycle. One I secured the middle sprayer arm the grinding noise went away.
Posted on Sep 20, 2007
Anonymous
  • 290 Answers
SOURCE: GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Posted on Oct 02, 2007
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: Fridge making a noise
You have a bad relay on the mother board. It is behind a panel on the back of the fridge. You can view a diagram at http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0165000&brandID=0432&modelDesc=REFRIGERATOR%20R%20SERIES&modelNumber=GSH25KGREWW&documentID=G0502132&documentTypeID=PLDM&documentClassCode=PV&titleType=SEALED%20SYSTEM%20%26%20MOTHER%20BOARD&titleID=00008& It is # 801. The part # is WR55X10552 and cost is $124.69 @ http://www3.sears.com/. I replace this board all the time. Make sure to unplug the fridge first!
Posted on Nov 03, 2007
Anonymous
  • 111 Answers
SOURCE: ge adora top load tub leans to one side, but works
There are 4 suspension rods that hang the outre tup from the top frame. One is the came off during the off balance load. Easy to put back on...Remove the front panel by inserting a putty knife where the top of the machine and the front panel meet inline with the lid opening while pulling towards you. You will then be able to see the front rods. The back two are harder to see but hopefully it is only one of the front rods that needs to be reset. When you see it and compare to one of the ones that didn't come loose, it will be obvious how it is attaches.
Posted on Dec 20, 2008
peyton32034
peyton thompson
  • 410 Answers
SOURCE: icemaker makes ice; door dispenser cranks, but no ice dispensed
sounds like either the dispenser motor is bad or the dispenser yoke is stripped. remove the bucket from the freezer. you will see a u shaped yoke in the rear of the disp area. this should be fairly hard to turn by hand if it turns easily then the motor gears are bad if the yoke slips on the motor shaft then you have a stripped yoke. hope that helps. peyton...
Posted on Jan 22, 2009
Veg and fruits freeze up.. Why? and what should temps be for frig and freezer?
We had this problem almost 4 yrs ago. It was the damper assembly which is a common problem w/ GEs. A damper is a door flap that opens and closes between the fridge and freezer that allows cold air into the fridge to regulate the temperature. Eventually, it breaks, allowing in too much cold air into the fridge, thus making both sides a freezer! Fixya's link that helped me is this one, which is very helpful: http://fixitnow.com/wp/2007/12/06/ge-side-by-side-refrigerator-freezing-the-beer/. You also might need to enter a diagnostic code when you replace it. Check this out also:
http://fixitnow.com/wp/2009/10/02/activating-self-diagnostic-mode-in-a-ge-arctica-refrigerator/. Don't let the description of the fridge as a GE Arctica mislead you. These are different models, but internally are the same components.
Jun 14, 2014 | GE Adora DSS25KSTSS Stainless Steel Side...
GE Adora dishwasher model ddt575smf0es leaking from condensation
Sounds like a poor install. If the hoses aren't collected correctly heat from water could cause expansion therefore looser doors and hinges. Make sure the water connections are tight and then check the screws at the bottom of the door. you shouldn't need a pro to fix.
Feb 25, 2014 | GE Adora GHDA654LBG Dishwasher
My GE Adora side by side makes ice but the water dispenser barely dispenses.
Did you recently move the fridge? One possibility is that the supply line in the back of the fridge is kinked. Usually it is coiled so you can move the fridge out and back damage but if it gets kinked, it would limit the water supply like a hose does when kinked. Also, the supply line is usually tapped from under the sink. Make sure the valve that supplies the line (usually 1/4 inch line) is fully opened. If that fails to help, then you're back to the solenoid valve for water that is not fully opening. Should give a solid clunk when actuated. G
Jan 27, 2014 | GE Adora (DSF25KGTBG) Side by Side...
My GE Adora seams to be breaking down. Freezer is not freezing and temperature in both, Freezer and Refrigerator is dropping. HAVE reset the temperatures to GE's recommendation of 0 Degrees and 38...
One thing you can do is make sure condenser coils have plenty of area around them (nothing lying against refrigerator) to prevent air flow. If possible vacuum and clean condenser coils and make sure freezer door is completely closed.
Aug 01, 2017 | GE Adora (DSF25KGTBG) Side by Side...
Ge Adora dryer model#DHDVH52EFOWW started making a screeching noise in the middle of a cycle and does it again if I restart it.
remove door and check horse shoe shaped plastic guides located at the top of the door that the drum rides on for wear....replace if worn
Jan 03, 2011 | GE Adora DVM1850 Microwave Oven
GE (Side x DSide) Adora: closing fridge door causes the freezer door to open
That will happen if you close the door too quickly or make sure the freezer door gasket is sealing properly.
Nov 20, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
My GE Adora Refrigerator is making ice but not dispensing it. What could be the problem?
The switch for the screwfeeder is probably not any good. With ice or not, the screwfeeder should turn when you push the handle in to dispense ice. If there is any ice in the hopper, it will get drawn in by the screwfeeder and sent out the dispenser door in to your waiting container.
Oct 08, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Makes noise vibrates when fan is running
The fans for those often bend or get out of balance...the best thing to do is to just replace the fan..have tried fixing them and the fix is only temporary once you start having problems...
heatman101
Apr 30, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Door panel doesnt work
Check circuit fuse,electrical connections,check your door circuit & buttons.
Feb 21, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Icemaker makes ice; door dispenser cranks, but no ice dispensed
Jan 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Ron Rak
Ron Rak
gbob59
