The second transfer roller might be missing. Is not properly installed. If you open the printer you will see a roller made of sponge like material. That is the second transfer roller. Replace it if above does not work also ensure the transfer belt is properly installed. that is across from it in the machine.
SOURCE: fatal error 14H
Try first rebooting the printer, if that doesn't work, reinstall/update all drivers. If that doesn't work, you need a service tech.
Error 14h is:
Service Call 14 XFER ROLLER: Incorrect pressure by or seperation from the Second image transfer roller..
not too sure on how to fix that if reboot/driver update doesn't work.
SOURCE: Fatal Error 14h 2300 DL
printer.konicaminolta.com/service/ASP/mc2300/.../mc2300SM.pdf
this link is going to take you the manuel that what you have to do when you got an error.
