The washing machine stopped functioning but the drum is not full of water. I need to remove the cloths and the door is locked.
SOURCE: Indesit WE14UK front loading washing machine door locked
try turning the timer knob/programme selector dial round to a black dot, switch appliance off then back on again. the red light should flash once, then pause, then twice then pause then three times. the appliance should now be reset and your door should open, if not there could be a fault on the main pcb control unit.
hope this helps
kj
SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
SOURCE: LG TROMM washing machine can't open door
You need to unplug the machine, and drain the water from the drain hose, accessing the drain pump.
Once you access the drain pump also remove all obstructions in drain lines, this often fix teh problem.
If you do not have done anything similar before, then it is better to call the technician.
SOURCE: whirlpool washing machine wont stop all lights
Check your washer plug to see if the connections are
tightly
screwed. Next check your filter if you haven't for long.
Remove
the 3 screws at the bottom of the front panel under the
washer door. Your filter door will be light brown. If you find a hose
there it is to drain out excess water (water that could not be drained
by your pump) After you hv drained unscrew the cap and
remove all the junk inside. Have a large plastic bag to catch junk and
water. Refit carefully after cleaning out. If not solved, something
shd be blocking your pump, check this out.
While the machine is on press "end of cycle" for 3 seconds, then wait
for 2 minutes to try the door. Try this again if it does not open, this
is the child lock program - to lock and unlock; it is the same
procedure.
How abt a nice rating
for the free help? Thnks
SOURCE: Indesit iwc6145 washing machine all lights flashed now not spinning or draining??
see the causes and fix it. God bless you
Drain Pump Filter
This is the most common problem. Some have a small cover in the lower
front put a screwdriver in the hole and turn counterclockwise to remove.
There will be a cover to remove, water will come out so be prepared
with a towel or wet vac. Clean this out. Other Machines will need to
access the drain pump to get to the filter. This can be done by removing the back panel on some washers. On others you will need to remove the lower panel or complete front panel depending on model. The filter is located inside the large hose from the tub to the pump. Remove the hose and clean filter.
Drain Pump
The drain pump may have failed. If you hear it making noises you will
need to remove the drain pump and check for obstructions, broken
impeller, or not spinning freely. Remove obstructions if it does not
spin freely replace the drain pump. If you hear it hum replace the pump if
nothing is found inside. If no noise is heard check the pump for power.
To do this remove the wire connectors and connect a voltmeter turn to a
drain cycle, refer to tech sheet or service manual for proper voltage
reading, usually any voltage would probally indicate a faulty pump. If
no voltage to the pump replace the main control board.
Hoses
Check the hoses from the pump by disconnecting them and make sure there
are no obstructions. Check your hoes drain, if it is a slow drain this
can cause your washer to not properly drain.
