Question about Water Water Heaters
ES40r92-45D No hot water and no error code has power
Posted by NANCY DAGLEY on
ray gallant
    Top Expert:
  • Water Master
  • 68,569 Answers
CHECK TEMP SENSOR
Posted on May 02, 2020
1 Related Answer
Anonymous
SOURCE: Water is way too hot.
Before calling service technician who has service manual and can test which part has failed, open following links for troubleshooting resources including steps below and phone number for Bosch:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ETechSupport/Troubleshooting/tabid/1131/Default.aspx
Clean inlet filter
Check all faucets for clear pathway
This unit does not work with preheated water (solar assisted)
Incoming water above 70 degrees, avoid restricted faucets
Check that both temperature sensors are making contact and firmly mounted on respective cold and hot pipes.
Descale heat exchanger
http://www.boschhotwater.com/Portals/7/TechBulletins/TWH-G2-13_Descaling.pdf
Posted on Aug 16, 2011
ER3 error code on amtrol hot water tank
Simply means hot water heater called for heat for 1 hour and never rose in temperature or reach stepping, unit automatically goes into lockout. I would reset power
Feb 14, 2015 | Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr...
Tip
Get hot water from your Rheem tankless during a code 76 error
This doesn't always work, but on the Rheem tankless Gas/Propane water heater, if you're experiencing a code 76 error; disconnect the remote control unit (either from the water heater or the remote) by lifting the wires for the remote connection. Typically you'll get a C1-C8 error code, followed by a code 76; if you're getting a straight code 76 and nothing else, this procedure probably won't work.
Code 76 is a total power supply failure on the printed circuit board (PCB) assembly, which is the communication/power supply for the remote control unit. But, if you're getting a supplemental code (C1-C8) this procedure will most likely supply you with hot water until the replacement PCB arrives.
on Dec 01, 2009 | Rheem Tankless water heater for 1-2...
C4 76 error code on richland waterheater
Richland tankless is made by Rheem.
C7-76 is communication fault with remote.
Turn off power at remote and wait 5 minutes, turn power back on at remote, and see if problem clears.
If problem continues, read below:
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, typical maintenance manual:
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Tankless water heater, more than any other type of heater, need to be maintained.
Maintaining tankless will probably not affect C7 76 fault code, but can prevent many other common error codes.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Sep 14, 2011 | Rheem Tankless Hot Water Heater...
Indoor tankless 74-pvn. power went off and has returned. get error code 24 when try to power on
Open following links for Rheem troubleshooting resources, including Rheem chat, error codes, and possible manual.
Error codes are considered start-point for troubleshoot.
Error code 24 is malfunction of operational switch: press max or min button on PC board to reset, -or- replace PC board.
Max-min button is sometimes located above dip switches, and can be 1 button that is rotated with screwdriver or 2 separate buttons. Look at wiring diagram in manual that came with product.
Fix most tankless problems yourself, same day, for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Aug 14, 2011 | Rheem Tankless Hot Water Heater...
PTG-53XN error code p1. And hot water turns off.
Before calling service technician, open following link for Rheem troubleshoot resources including Rheem chat:
Error codes are considered start point for troubleshooting, and can sometimes mislead.
Error P1 is 'not enough water to operate the unit:'
http://waterheatertimer.org/pdf/Rheem-Error-code-P1.pdf
This problem can be caused by plumbing problems such as crossover, or clogged water lines, or dirty water filter, or clogged water softener, or temperature of unit set too high. Or combination of these problems.
Remember if temperature is set very high, then more cold water is used at the faucet. This means less hot water is drawn through the tankless water heater, so the flow rate may drop below activation threshold.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Low-hot-water-pressure.html
Jul 08, 2011 | Rheem Tankless Hot Water Heater...
Hi i have a power vent water heater model #-6g40pvw-40f. It go's into lock down mowed one light lit on vaction two more on A-and B is it the heating element or lighter mechanison thank you mike from...
Hello Mike,
Check gas pressure, burner parts need to be cleaned, check electrical outlet, hot surface igniter is bad
White Rodgers intellivent error code:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#Intellivent
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
Error code says: system in lockout, but you know that.
1) Low gas pressure, no gas to water heater: call gas company to check pressure
2) Hot surface igniter not positioned correctly: inspect and clean burner parts.
http://waterheatertimer.org/images/Reliance-hot-surface-ignite.jpg
3) Low voltage to water heater/ outlet has wrong polarity: Use circuit analyzer on electrical outlet to make sure polarity is correct
Typical power vent manual:
http://waterheatertimer.org/pdf/Reliance-40-50-power-vent.pdf
Cleaning water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
http://waterheatertimer.org/pdf/How-to-clean-combustion-chamber.pdf
Jun 19, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
What is error code 043 on NORITZ tankless heater?
There is no error 43 on a NR71. There is a 73 error code which is caused by disconnecting jumper cables while the power is on.
Oct 29, 2010 | Noritz 7.1 Gpm Propane Lp Gas Tankless Hot...
I am getting error code -0 and 82 PTG-74PVN
Remove power, disconnect remote terminal. Restore power, open a hot water valve and see if you get any hot water.
HTH,
Mike
Nov 15, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Water Heaters Logo
156 people viewed this question
Top Water Heaters Experts
Don Walper
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Water Heater Expert? Answer questions, earn points and help others
