Question about Boating
I looking for power cord for bottom line EZ4400 fish finder
Posted by Harold Schettler on
5 Related Answers
Anonymous
  • 64 Answers
SOURCE: i need a manual for humminbird wide 100 fish finder
You can find the manual you need at: http://www.humminbird.com/support/FAQ.aspx?faqid=72
It is listed in the legacy products area with the wide series of units.
Posted on Nov 26, 2008
Anonymous
  • 385 Answers
SOURCE: Need user manual or info on how to use
Try here, be quick, it could be gone soon,.
http://cgi.ebay.com/OEM-Bottom-Line-TBL-100-Fish-Finder-Owners-Manual_W0QQitemZ330327439511QQcmdZViewItemQQimsxZ20090504?IMSfp=TL090504126009r38275
Hope this helps
Regards
Posted on May 26, 2009
Editor925
Dean
  • 285 Answers
SOURCE: CAN I POWER MY FISH FINDER GOING DIRECTLY TO THE
Yes you can. Basically the red wire goes to the fuse box connection. The fuse box should then be wired into the positive battery terminal. The black wire is the negative ground wire and needs to go directly back to your negative battery terminal or to a common negative buss bar.
Posted on Jun 15, 2009
tbirdfan1
Michael Thomas
  • 3056 Answers
SOURCE: fish finder manual
hello there:
here is a link that will help you get the manual u need ok?
best regards micha
Eagle 250 DS - FishEasy GPS safe.gif Learn more about the Eagle FishEasy 250 DS before you decide to buy. Download User Guide and Manual ... fish finder EAGLE FISHEASY 250DS. www.bestfishfinder. ...
www.retrevo.com/s/Eagle-250-DS-GPS-review-manual/id/23493bh848/t/1-2 - 69k - Cached el
Posted on Aug 27, 2009
Kathy Lewis
SOURCE: Bottom Line Tournament 1101
You can get a manual free by calling 1-800-456-5432. The Bottom Line Tournament 1101 is made by Hummingbird. I got the number from a sport shop here in Roseburg, OR. Called it and they're sending me the manual free! Good luck. -- Gary
Posted on Sep 05, 2009
Does anyone have a power cord for a BOTTOM LINE TOURNAMENT 480 MAX FISH FINDER????I have one that was my dads and I would like to get it back out on the water...any help you can give would be great!!!
Hi Michael
The 480 max has been discontinued for quite some time now.
I would suggest contacting
Computrol, Inc. 499 East Corporate Drive
Meridian, Idaho 83642-3510
TEL (208) 846-9000
FAX (208) 887-2000
www.bottomlinefishfinders.com
to see if that cord is still available from them.
-Steve
Oct 26, 2014 | Boating
I have a eagle z-5000 lcg recorder that came with my boat, but don't have the power cord or the line that goes into the water. can i get a parts list that I can order them through.
yes, I have the part you need for your Eagle Z 5000 lcg recorder. I have the power cord, transducer with over 25 ft. of cord and complete with a fish finder Z 5000 of which depth finder does not work. You can have it all for $75.00 plus shipping Please contact me by email [email protected]
Thank you
Jul 14, 2011 | GPS
I need a power cord for a Tournament Master HR Bottom Line fish locator. Where can I find this cord?
Do you still need the power cable? I have a new unopened power cable.
Dave
Feb 10, 2011 | Boating
My hp ez4400 starts up but quickly shuts down ,
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 28, 2009 | HP Computers & Internet
What battery (6V or 9V) do I use for my Bottom Line fishfinde
Normally more fish finders operate on 12VDC. The red is normally positive and black negative. As far as the wiring goes. I have never heard of this brand before but I would search around before hooking up the wires. Sometimes the colors are different than you think.
Oct 16, 2009 | Boating
It doesnt work no bottom in feet no fish
Sounds like either the sensor is broken or the line going to the monitor is cut or frayed. Its possible you might have to replace the line. Just in case though check to see if the line to the monitor is loose. That might be your problem right there.
Jun 30, 2009 | Bottom Line Fishin' Buddy 1101 GPS...
Jun 15, 2009 | Humminbird Fishfinder 565 With Transom...
Bottom Line Fishin'Buddy II Fish/Depth Finder user guide/manual?
i have an older fishin buddy 2 bottom line sidefinder i need a manual, a bracket that holds it to the boat and the battery holder / handle i hope you can help me with this my email [email protected]
May 09, 2009 | Boating
Installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Apr 26, 2008 | Lowrance LMS-332C GPS Receiver
Boating Logo
146 people viewed this question
Top Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
