Computers & Internet Logo
B
Brent Basara Posted on Jan 25, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Se55ugt does not save internet ip - Internet Computers & Internet
Robbie Goodwin
Level 2:
Sergeant:
  • Expert 384 Answers
  • Posted on Jan 27, 2019
Robbie Goodwin
Expert
Level 2:
Sergeant:
Answers
384
Questions
0
Helped
88047
Points
989
Exactly how do you know that?
Does it give a specific message saying it's lost its IP address?
If not, how d'you it failed to save the IP address?
2helpful
How do I find my IP address of my sansui TV
Your TV has no independent IP address. The IP address correponds to YOUR internet connection and you can get it making a Google query for "My IP"
Actually, to save you the work for searching, you can use this link
Cul Es Mi Direccin IP WhatIsMyIP com
Static ip
Control Panel.
Network Connects, then.
Right click Local Area Connection and select properties.
Select Internet TCP/IP or V4 and click properties.
Select "Use the following IP address"
Now you should be able to set your static IP.
Click Ok to save changes.
Take care!
damnor01
1helpful
What is the gprs/mms setting for sony ericsson X8? my network provider is globe philippines. i went to their customer service but even the representatives there can't help me with my problem.
Just follow this Guidelines
GPRS SETTINGS
1. Go to Menu>Choose Settings>Connectivity
2. Go to Data Accounts
3. Create New Account. GPRS/ PS Data
Account Name: MyGlobe GPRS
APN: www.globe.com.ph
4. Save Account
5. Go to Browser, Slect Options and click Internet Settings
6. Add New Profile
Connect Using: MyGlobe GPRS
IP ADDRESS: 203.177.042.214
ADVANCED
Chg. Homepage: MyGlobe GPRS
Address: http://www.globe.com.ph/globe.asp
Save Profile
MyGlobe Internet Settings
Account Name: MyGlobe INTERNET
APN: internet.globe.com.ph
4. Save Account
MyGlobe MMS Settings
Account Name: MyGlobe MMS
APN: mms.globe.com.ph
4. Save Account
5. Go to Messages>Picture Messages>Option>Internet Profile
6. Create New Profile
Connect Using: MyGlobe MMS
7. Save Profile
8. Select the profile MyGlobe MMS in Internet Profile
9. Save Settings
10. Go to Messages>Picture Messages >Options
11. Edit Message Server
http://192.40.100.22:100.21/mmsc
12. From Message Settings, make your Internet Profile: MyGlobe MMS
Hope it helps...
4helpful
Checking virtual IP servers... [VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED] [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [FAILED] *** 'COMPONENT_TYPE_WININET' value:...
1) Clear your browsers out
Download 'ccleaner' and use it daily. Run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_ccleaner/
Open Internet Explorer (even if you use another browser as default) > Tools > Internet Options > Connections tab > LAN settings > Uncheck all the boxes and check "Automtically detect settings" > Save > Save
I have WG11v3, adapter and have all lights ready except. It tells me about the ip address is needed. How can I put that in. I provider is verizon and they tell me I will have to get that answer from...
Click on Start and then Control Panel. Select Network Connections. Right click on the local network adaptor you are setting the IP address for. Select properties. If you do not see Internet Protocol (TCP/IP) click the install select protocol and add then Internet Protocol TCP/IP and ok. Click on Internet Protocol (TCP/IP) and properties. If you do not know the IP Address select obtain IP address automatically and OK. Click OK to close and save Local Area Network Properties. See if this works otherwise you will need to find the IP Address for your modem.
2helpful
Dlink WBR 2310 cannot connec to internet
Try to bypass the router and connect to your modem. Make sure you have Internet connection.
>If you have Internet connection. connect back your modem to the router.
>access the configuration page of your router.
>If you are given a specific IP by your Internet Service Provider, use that one.
>Login to your Dlink (type in on the address bar 192.168.0.1)
>Click Setup and Internet > Click on Manual Configure
>My Internet connection would be Static IP
>Type in your IP address, Subnet Mask, Default Gateway, Primary and Alternate DNS
>Click on Save Setting on top.
but if your Internet Service Provider did not provide you those informations
> Under My Internet connection Type choose DYNAMIC IP
>Click on Clone Your PC MAC address
>Click on Save Settings
>If it ask you to reboot, click on Reboot.
>At the very top click on Status
>Under Status look for WAN
>Under WAN look for IP address
>If you have values beside from zero it means you have Internet connection otherwise, call your dlink manufacturer for manual configuring your router for Internet connection.
Saving my ip address
The PSP automatically do saves your configuration while to create a connection through wi-fi
D-link di514
Try the DSL modem directly connected to the PC.No D-Link Router(powered off and disconnected). Verify that the PCcould surf/browse/connect to the Internet. Go to Start, Control Panel,Network Connections, right click Local Area Connection, Properties,scroll down to/highlight Internet Protocol (TCP/IP), Properties button.Get the IP Add, Subnet Mask, Default Gateway and DNS assigned to the PC(write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router.Go again to Start, Control Panel, Network Connections, right clickLocal Area Connection, Properties, scroll down to/highlight InternetProtocol(TCP/IP), Properties button. Tick "Use the following IPaddress". Enter this IP Add 192.168.0.10, Subnet Mask255.255.255.0,Default Gateway 192.168.0.1 and the DNS from what youhave written down earlier). This will be your LAN IP settings. OK,close, save or whatever is applicable.
Open a browser and log into the D-Link router (192.168.0.1, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Usethe IP numbers previously assigned to PC that you have written down asthe router's WAN/Internet/Modem IP settings. OK, close, save orwhatever is applicable. Reboot router. Connect DSL modem to router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
DI 524 Connection Problem
Try the DSL modem directly connected to the PC.No D-Link Router (powered off and disconnected). Verify that the PC couldsurf/browse/connect to the Internet. Go to Start, Control Panel, Network Connections, right click Local Area Connection, Properties, scroll down to/highlight Internet Protocol (TCP/IP), Properties button. Get the IP Add, Subnet Mask,Default Gateway and DNS assigned to the PC (write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router. Go again to Start, Control Panel, Network Connections, right click Local AreaConnection, Properties, scroll down to/highlight Internet Protocol(TCP/IP), Properties button. Tick "Use the following IP address". Enter this IP Add 192.168.0.10, Subnet Mask 255.255.255.0,Default Gateway 192.168.0.1 and the DNS from what you have written down earlier). This willbe your LAN IP settings. OK, close, save or whatever is applicable.
Open a browser and log into the D-Link router (192.168.0.1, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Use the IP numbers previously assigned to PC that you have writtendown as the router's WAN/Internet/Modem IP settings. OK, close, save or whatever is applicable. Rebootrouter. Connect DSL modem to router.
6helpful
2answers
Cannot access the internet through my DIR-625
Check your IP address to 192.168.10.1 on the network settings
after that turn modem and VoIP off.
Click on Setup / Manual Internet
Select Dynamic IP under "My internet connection is"
Click on "Clone Your PC's Mac address"
Click on Save settings, if it ask for reboot click on reboot
After the router reboots (NOT COMPUTER), it will take you back to the router.
Once your are in the router, turn the modem on first then the VoIP.
After the modem and VoIP has finish rebootin
Click on the status tab of the router and check uder the "WAN"
Settings and check the IP address. If you get an IP address then check the internet.
If you do not get an IP address Click on Release and then renew.
If you still do not get an IP address click on Advance tab
Click on Advance network on the left and turn UPNP off and save the settings.
After that it should be able to get an IP address and you should be able to get online.
 Grubhead
Grubhead
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
Paul Bade
