Vestax Vci 100 Midi Controller Logo
Posted on Aug 05, 2009
Traktor not responding to vci 100. data being sent from controler as midi flashes but no work.
Mrmidnite Thesupremeruler
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 09, 2009
Contributor
Level 1:
Answers
Questions
0
Helped
961
Points
Check vci100 highlighted in midi device section of traktor
I recently upgraded my operating system (to Mac OSX 10.6) and now my VCI-100 won't show up as a device. Any advice on how to resolve this?
Here is an online manual, Can't download it, though. Hope it helps.
http://www.manualslib.com/manual/399951/Vestax-Vci-100.html
The 4 black buttons in a column at the top left hand corner of the vci-100. The second one down from the top isn't sending data, and the button is kind of squiggly. I know this may just be normal wear...
The solution is likely replacement of the button switch portion. Be careful of applying too much pressure... often they have plastic hinges for the buttons and they can be broken by applying too much pressure in an attempt to get them to work.
Hello i cant seem to find a driver for my vestax vci 100 for my macbook 10.6.3 plz help thankyou
well what software are you using. They is plug n play capable w VDJ and the drivers if there any should be on vestax's site or on a disk that came w the software. and if you need mappings for it meaning to your controller works with tratoktor www.djtechtools.com like i said you might not need a driver for it but let me know
Im using my vestax vci 100 mk2 with my macs built in speakers.i am only able to hear the sound ouy of my headphones and if i choose built in speakers as an option in the set up wizard i can only hear the...
It is an either/or thing. I would recommend you get a headphone amplifier or get external speakers and drive them externally. Internal speakers are relatively poor quality anyway
Where can i send my vci 100 to get repaired ? neil mk
You don't give your location so start here:http://www.vestax.com/v/ Try contacting the two distributors here:http://www.vestax.com/v/wtbuy/ .
1helpful
2answers
Vestax vcm 100 driver traktor pro
hi, you need to go here:
http://help.vestax.co.jp/en/detail.php?id=80&id_page_url=56&cate=0
and download the .tks file for your version of Traktor. Suggest you save it to the Traktor program directory.
Then within Traktor in the controller settings section, load the .tks file, save and you're good to go. Obviously you can tweak the configuration as much as you like once it's loaded. Suggest you always keep a backup of the original.
Top Vestax Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Vestax Music Expert? Answer questions, earn points and help others
